Introduction: Make a Microphone Stand --With a Tripod
I wanted a mic stand to use when recording sound to the computer, but being the low-budget cheapskate that I am, I decided to make one.
Rather than making a full custom stand, I built a holder that attaches to a camera tripod. This is not the ideal base, due to the legs sticking out everywhere, but I can work around that. It is a completely separate unit, so the tripod can still be used with the camera. The need arose, the idea was formed, the stand was built and the Instructable was published in one afternoon. It's not that hard.
Obligatory safety notice: This Instructable uses sharp objects. Be careful.
Step 1: You Will Need...
Materials:
-scrap 1x2, about six inches long
-scrap foam (not rigid Styrofoam-type stuff, something squishy)
-rubber bands
-glue that will bond to the foam and the wood
-tripod
Tools:
-saw to cut the 1x2 to size
-No. 7 drill bit (.2010 inches)
-1/4x20 tap (that's 1/4" inch, 20 TPI)
-drill or drill press
-knife (or other Sharp Object to cut the foam)
Step 2: Cut Out the Base and Foam
Get out the largest microphone you plan to use with this holder, mark the 1x2 to length, and cut it off. There is no need to be exact. Next, draw the outline of the 1x2 on the foam, and use a sharp knife to cut it to size.
Step 3: Drill and Tap Base
Now we'll drill and tap the base. The standard size for tripods is 1/4" at 20 TPI. This tap requires a No. 7 drill bit, which is .2010", about 13/64" if you don't have a numbered set. After drilling all the way through close to the center (no need for exactitude, remember), break out the tap and thread that sucker. Do a quick test fit to make sure it fits the tripod, just in case you grabbed the wrong tap.
Step 4: Attach Foam Padding
The foam serves two purposes here: it pads the microphone from the base, thereby keeping the wood from scratching the mic's finish, and it provides an acoustic buffer to cut any vibrations. Dab some strong glue onto the wood, keeping it away from the hole, and attach the foam. It's best to let this cure completely before moving on, although I waited until I could pick the whole thing up by the foam and moved on.
Step 5: Attach Stuff and Rock Out!
The microphone attaches to the holder with a couple of rubber bands, and the holder attaches to the tripod with the standard screw. Not particularly difficult, really.
The main improvement I can think of is to drill out the wood farther and epoxy in a nut to save wear and tear on the wood. You can also use this as a holder for other stationary cylindrical objects (cough laser pointer cough).
8 Comments
12 years ago on Introduction
What's the foam for?
15 years ago on Introduction
This project really fell together well. The rectangular mic I'm using goes to a dictation machine. These are reusable IKEA zip ties, the rigid area on them holds perfectly. The rubber bands work with my cylindrical shaped microphone and they will buffer mechanical noise better too. One discrepancy I encountered was that of the sunken bolt. Here I hammered it in and chipped the wood a little. What I experienced with the contact between the tripod and block is either way you make it, the thing wants to come unscrewed. My solution will be the use of felt surface guards or liquid rubber. In addition to finding a better contact method I'll cover the mounting nut with a thin construction bracket, as soon as a return from the hardware store. One thing we need on this is a pop filter, this one I'm not wild about. I'm trying to make a filter that could be collapsible and attach to the design you came up with. Anyway your solution is quick, inexpensive and works so I'll vouch for it.
This sure blows away the ad-hoc gaffers tape to the lamp idea. This gives me a lot of ideas such as the use of high density foam, adding a DIY pop filter and a cable clamp. good stuff+
Reply 15 years ago on Introduction
Thanks! I've had the idea for the holder for a while, but didn't know what to attach it to.
I've been trying to figure out a way to do something like this. I like yours!
Not that you would have a tripod to do it with...
hehe
awesome idea, never thought of this.
