Make a PVC Microphone Shockmount for $1.20
Intro: Make a PVC Microphone Shockmount for $1.20
What is a shockmount? If want to record dialogue for your movie, using a shotgun mic on the end of a boom pole is a good way to capture it. The problem is that if your mic is connected directly to the pole, it will pick up noise from the operator's hands. A shockmount suspends the mic up and away from this potential noise.
A few years ago, I published an Instructable for a rubber band mic shockmount that was became featured on the home page. I received positive feedback, but after finally using it in the field, I didn't like it. The rubber bands tended to move too much and the whole thing looked cheap. I think I've come up with a better build that is tougher, easier to make, and less expensive.
STEP 1: Parts List
1/2" PVC pipe scrap (2.5" long) - FREE (or just over a buck for a 10' length)
4 rubber bands - FREE (rubber bands are everywhere)
1 1/4" x 1/2" Tee fitting - $1.20 at Lowe's
STEP 2: Tools
Pencil
Dremel
PVC ratcheting cutters
Dremel
STEP 3: Place Bands Around Large End of Tee Fitting
The idea here is to create a narrow hole for the microphone to rest in.
STEP 4: Mark Where Bands Lie With Pencil
Leave a mark on both sides of each rubber band. Pencil is better than ink as you can easily rub off leftover marks when done.
STEP 5: Remove Bands, Dremel, Replace
Time to create the notches which will give the bands a firm grip on the tube.
STEP 6: Insert PVC Pipe and You Are Done!
If you like this kind of thing, come check out The Frugal Filmmaker!
10 Comments
svarnell1 11 years ago
I would have painted the whole thing too, because PVC has low UV resistance and it will discolor. Flat black would probably be the best.
spaceinvaderx 13 years ago
stevo1994 13 years ago
mrbones121 14 years ago
CrLz 14 years ago
I'd suggest trying elastic hair bands (ponytail holders) for a nicer looking rubber band. I've found the hair ties to last longer and the fabric covering looks good.
manutea 14 years ago
fixmystuff 14 years ago
photodude 14 years ago
