Introduction: Make a Pipe From a Branch
I cut a branch from my grandma's cherry tree and it looked like a pipe. So I let it dry and turned it into a pipe. Welcome to this instructables.
Sidenote on the photos :
At the end of a sunny day in my granddad's workshop, the warm sunlight shines through the window directly on the bench and workpiece, resulting in a beautiful contrast with the cool shade of the workshop. This makes a great setting for beautiful pictures if you focus the camera on the brightest part of the object.
Step 1: Tools/Materials
The only specific tool you really need for this project is a long drill bit, I used a 10mm * 400mm from amazon (less than 3 euros as an add-on)
A drill to put the drill bit on duh
Then a food-safe finish of your choosing (I chose as usual a Hexane:Paraffin oil 1:2 mix)
Some sandpaper (a belt sander is nice!)
A knife
A drill-bit the size of your projected burn chamber
Step 2: Drill
This may look straightforward buuut.... Drilling straight is harder on a longer length so plan carefully.
I drilled the tube first, marking on the wood how deep the bit went, then orthogonally predrilled the chamber, then enlarged it.
Tips to avoid overheating of the drill bit when drilling for a long time : proceed slowly, take the drill bit out often to avoid clogging with dust and drill through a piece of soap once in a while to lubricate. Oh and cool the bit in water.
Step 3: Carve!
So this drilled piece of wood looks a bit rough ! I removed big chunks of material with a knife then finished carving on rough belt sander paper.
Step 4: Sand
Pictures are worth a thousand words.
120 grit through 400, using bricobart's method sadly no pictures because of not enough hands.
Step 5: Finish
I applied my homemade mix, being careful to not put any in the bowl!
There you go! Thanks for reading :)
Maker Olympics Contest 2016
Wood Contest 2016
9 Comments
5 years ago
smoke weed every day
5 years ago
Nice work! How long before the branch was properly seasoned (dried)? Did you dry it bark-on or bark-off? Let me (us) know and I'll be looking for windfall branches in the park after the next storm.
Reply 5 years ago
Thanks! We cut the branch in April and I let it dry for a month with the bark on, then peeled it and dried it for 3 more months. It cracked a little bit as you can see on the pictures but no leaks whatsoever and it is really dry. It was not very thick though (3 inches/10 cm in diameter at most I'd say). When you start drilling you'll soon notice whether it's still green or not :)
Reply 5 years ago
Oh I should mention that the branch had been dead (no leaves or anything) on the tree for at least a year or two. So I guess it is the kind of branch susceptible of falling during a storm. Have a nice branch hunting!
5 years ago
Nice work but you want to use a hard wood beach birch rosewood etc no pine cedar etc
Reply 5 years ago
This is cherry
5 years ago
very nice work!
Reply 5 years ago
Thanks !
5 years ago
Cool!! Very interesting.
