Introduction: Make a Rainy Day Tissue Box Guitar! - Great for Kids
I'm going to show you how to make a guitar with your kids out of a tissue box, paper towel roll and some rubber bands! My mom and I used to make these all the time when I was little - They're really fun!
Step 1: Tools & Supplies
The stuff that you need is pretty simple...
Empty tissue box (the long kind)
Empty Paper Towel Roll
3 Rubber bands (You may want another in case one snaps)
Tape
Something to cut with
Marker
A kid ready to have fun! (The inner kid in you works too :D)
Step 2: Cut Off the Cellophane
Cut around the edge of the opening to get out the plastic that the tissues come through. This will make it easer to strum.
Note - If you're doing this with a small child, make sure you do all of the steps that require use of the knife/scissors.
Step 3: Cut Hole for the Neck
Now you're going to be making a hole in the box for the neck/paper towel roll. Go to one of the small sides of he box, and put your paper towel roll on top. Use your marker to trace around the roll, and then cut out the circle.
Step 4: Insert the Neck
Now, just insert the neck into the hole about 2 inches. If there is much space around the neck, and it doesn't stay well, stick tape around it to help stop it from sliding.
Step 5: Add the Strings
Now you can add the strings, just put a rubber band around the box, one on each side of the neck. You can also put one straight in the middle by cutting halfway through the neck right at the base, sliding a rubber band into the slit, and taping over the where you cut. (You can go ahead and play it now)
Step 6: Extra Things to Do
Here are a few extra things you can do to make your guitar even better!
1. Add bridges (suggested by lemonie)
2. Make different tones using different types of rubber bands (suggested by lemonie)
3. Add space for strumming
Adding Bridges
Bridges raise the strings of a guitar off the base, allowing the strings to vibrate freely in the air, producing better notes.
What you need:
2 index cards
tape
1. Fold up the index cards so that they are a little less than a cm wide.
2. Place under strings at the very top, and bottom, of the base of the guitar. Then tape to the box on the sides, where the tape won't interfere with the strings.
Different Notes
Using different size and thickness of rubber bands will change the notes they produce when plucked.
What you need:
Different rubber bands!
1. Just replace the old strings with new ones
More Strumming Space
If you're like me, the strings would sometimes hit the box as you played, this is how I solved it.
What you need:
Your cutting device from before
1. Figure out which way you hold the guitar, and then determine which side faces down as you play.
2. Cut out as much space as you need from the bottom of the hole. (when you're holding it, NOT the thin side) I needed about a centimeter.
Step 7: Decorate!
Use whatever you want to make your guitar prettier! Stickers, crayons, paint, whatever you have!...You're done! Now you can go and start a rock n' roll band!
19 Comments
7 years ago
This is a great idea! Keeps my little sis busy for hours!
7 years ago
maybe attach strings at different lenths to make different sounds
13 years ago on Introduction
wrapping paper tubes they are long enough to go all the way through and still stick out.
15 years ago on Introduction
heh I saw this on blues clues when I was like 6 but it is still so AWESOME!!!!
these osudned wierd. made em when i waas 6
ha the irony rainy day you say?
Reply 15 years ago on Introduction
Where's the irony?
its blazing sunshine outside
ohhhh..but now I can play while it's raining.
16 years ago on Introduction
i remember making this at primary good times
16 years ago
I love your project; the stickers add a nice touch, too!
Reply 16 years ago
Thanks :D They're left from the most recent "Birthday Crown" my Mom has made. Maybe I should have an instructable on those too :P
16 years ago
is this entered in the popular science contest? It is the epitome of recycled, i'm sure you will do well...
Reply 16 years ago
Actually - It is - Thanks for noticing!
16 years ago
Yea!
Reply 16 years ago
Does that mean you like it? :D
Reply 16 years ago
Yes, I do. I was thinking of bridges and differing gauges of rubber-bands, but I see how this could so easily keep kids (or adults) amused. Having hacksawed coconuts, this is something I really should have thought of. L
Reply 16 years ago
I think ill add both of those ideas to the instructable...tomorrow - Thanks. I had thought about the different types of rubber bands. but never thought of making a bridge.
Reply 16 years ago
Cancel that - I decided to do it now. I added another step showing your ideas and one of my own. I also added a sound clip in the intro of how it sounds.
