Make a Spin Dryer From a Discarded Washing Machine Drum, an Abandoned Bicycle and a Pallet.
Intro: Make a Spin Dryer From a Discarded Washing Machine Drum, an Abandoned Bicycle and a Pallet.
After over a decade of doing our laundry with a home-made bicycle washing machine, we finally decided we needed the spin function too. With our 'new' spin dryer we can achieve a spin cycle of between 320 and 400 rpm which gives us 'non-drip' laundry, which we could never achieve with our bicycle washing machine.
STEP 1: Main Components, Extra Materials & Tools
This is not a one-size-fits-all project, you have to reference your actual machine and all its component sizes (drain hose diameter, screw threads, etc.,) to the build. My machine being French, means all the threaded components are metric and I have also noted that some of the threaded bar/rod, sold in the US, for example, is now also in metric. So rather than my directly translating these dimensions into Imperial, which would not be appropriate, just substitute your machine's fastener sizes.
The Main ComponentsThe Bicycle: These wonderful machines are very often discarded long before their useful life has ceased, so can be bought, very cheaply, from secondhand shops, yard sales and many other sources. Alternatively, one can just intercept them before they get thrown into the dumpster. In my case, items like these are 'fly-tipped' behind our village bottle-bank and it is always worth my checking occasionally to see if any have been left there. The one I'm using for this project is from this latter source and is a well-used Rolland (now Jacquot) of Versailles. The major components of this i.e. frame, crankset and rear wheel hub were still O.K. for my needs.
The Washing Machine Drum: An old top-loading model that was badly corroded around the base was given to me by a friend. The drum and drum housing, including the bearings were still serviceable. If you can't get hold of a dead washing machine with a watertight drum and believe me at least one of your friends/family/neighbours has one tucked away in their garage, then you can use a couple of different sized plastic water barrels. However, if you are not worried about where the water goes, i.e. you have this set up in the backyard, then just one will suffice, plus that way you also get a free shower!
The Pallet: A non-standard sized untreated* pallet long enough to fit the bicycle and the supported drum was selected. For the layout of my components the pallet size was: 135cm x 80cm (53" x 32").
*(please see my articles, referenced at the end, on how to find and identify them)
Extra MaterialsStands - I used the metal ones I had created for a previous pedal-powered washing machine but included in this build will be a section on how to make wooden ones from untreated pallet wood.
Pallet Wood Planks Various sizes and thicknesses
Nuts, Bolts and Washers to fit:
Threaded bar - with regard to sizes as detailed above, this will need to correspond to the existing threads on the washing machine.
Additional Bicycle Chain - approximately 10" (250mm)
Vacuum Cleaner Hose - recuperated
ToolsAll of this build can be achieved with hand tools but if you have them and the power to run them, then obviously it will be quicker if you use power tools for some of the build:
- taps and dies
- spanners
- screwdriver
- wood saw
- hacksaw
- vice
- angle grinder
- electric drill
- lathe (optional)
- tape measure
STEP 2: The Design
The criteria for making a successful spin-dryer was to be able to increase the drum rotation speed such that the wet contents of the drum would be forced against the drum wall by centrifugal/centripetal force and the water would pass through the perforated drum wall. The faster the spin speed the greater the force and hence the more water should be expressed out of the laundry. In addition, the duration of spin would also affect the water removal.
The position of the drum in relation to the bicycle was also an important consideration: whether the drum is in front of the bicycle or behind makes a difference to the overall pallet size and chain length. I had already found that the smallest footprint would be achieved with the drum in front of the pedals rather than behind.
The washing machine had a direct drive from the crankset to a chainwheel attached to the drum shaft. They were the same size and thus had a 1:1 gear ratio. For the new project I used the smallest gear from the rear wheel gear cluster on the drum shaft which would raise the ratio to 1:3.2. Initially I had thought of having the same 'fixed wheel' arrangement between bicycle and drum as on the washing machine but after a discussion with some undergrad students on design choices for the spin-dryer I decided to see if it were possible to use a freewheel hub instead.
STEP 3: The Build - the Gearing Cluster
As I mentioned earlier, the exterior housing of the washing machine was not in a sound state, so I removed the drum/pulley wheel assembly from it.
The first part of the build was to obtain the rear wheel cluster and hub from the bicycle. I clamped the wheel by its spindle in the vice and removed the spokes using a cutting disc in the angle grinder. The spokes from the wheel hub on the other side to the gear cluster were the first to be removed, allowing easier access for the cutting disc to those fixed nearest the cluster. Once all removed the last remaining portions of the spokes could be ground out from the rear of the hub.
I then needed the bearing and housing removed from the remainder of the rear wheel spindle housing. Once again using the cutting disc I removed the other end of the spindle housing which then enabled me to clamp it in the vice and cut the bearing and its housing from the rest with a hacksaw.
The bearing and housing fitted into the gear cluster and a 10mm threaded bar was used instead of the wheel spindle. Matching nuts either side of the cluster held the cluster securely in place.
The problem I was now faced with was, for the bicycle/drum configuration I had opted for, the hub would have to fit into the drum shaft with the smallest gear of the cluster nearest to the drum. This would still let me pedal in the conventional, cycling direction to turn the drum. The drum shaft was threaded at the end to accommodate an 8mm screw so I needed to reduce the threaded spindle from 10mm to 8mm and cut a new thread to fit.
I held the free end of the 10mm shaft in the chuck of my wood-turning lathe and reduced the shaft diameter using the angle grinder whilst the lathe was in motion. I had an 8mm washer as a go/no go gauge, checking the fit frequently to ensure I did not remove too much from the spindle diameter. Once I got my gauge washer to fit down the ground portion, I clamped the 10mm end of the shaft between two pieces of wood in the vice (to prevent damage to the thread), filed a chamfer on the free end of the 8mm section and cut the thread with an 8mm die.
The newly-made shaft could then be screwed into the drum shaft and the gear cluster secured to the 10mm portion of this shaft. A visual check was made to ensure the gear cluster was running concentrically with the drum shaft.
STEP 4: The Build - Attaching the Bicycle
It was now time to attach the bicycle to the pallet. The bicycle was supported on two axle stands that I had made for our original; pedal-powered washing machine. The metal supports were fixed to the pallet using wood screws. These were of welded construction. If I had not had these available, I would have made new ones using pallet wood as I did for our 'new' bicycle washing machine. You could find this in my Washing Machine Instructable but I'll set it out again here to keep everything together.
Pallet Wood StandsThe important dimension was the height of the stand necessary to obtain the clearance between the pedal at its lowest point and the pallet. In my case this was about 12" (300mm). The vertical supports of the stands were stiffened with angled braces which extended to the stand base. Each stand had front and rear 'feet' which were screwed to the pallet and extended across at least 4 of the pallet's planks (this was to distribute the weight of the bicycle and the cyclist).
To give you some sort of idea of the sizes of material used, I list them below:
Stand uprights: 3" x 1" x 12½" (75mm x 25mm x 310mm)
Base: 3" x 1¾" x 8½" (75mm x 32mm x 210mm)
Feet: 13" x 3½" x ⅝" (325mm x 85mm x 15mm)
These are all recuperated untreated pallet wood.
The bicycle fork ends were supported on 10mm threaded bar.
For fitting the the supports onto the length of the pallet, I made both of them in the shape of a right-angled triangle.
The rear support comprised the uprights, glued and screwed to the base. The diagonal braces were glued and screwed to the inside faces of the uprights but did not go to the top of the upright so as to permit the fitting of the fork ends onto the supporting bar.
Packing pieces of the same thickness as the uprights were glued to the inside face of the base so that the braces could be screwed to a flat face at the same level as that of the uprights. Once the glue was dry, the stand was glued and screwed to the two 'feet' and the clearance holes for the supporting threaded bar were drilled in the uprights about 1" from the top edge.
The front support was a slightly different design in that I needed the fork end nearest the machine or in this case drum, to be on the outside face of the support. This was so that the bicycle chain wheel will align with that on the drum shaft. I also made a housed joint for the one upright (see image).
The support was also asymmetrically mounted on the feet this, to ensure the proximity of the bicycle to the drum. As with the rear support the holes for the threaded bar were drilled 1" from the top edge of the uprights.
STEP 5: The Build - Attaching the Drum
The drum mounting was more difficult. As was explained at the beginning of this post, the housing of the machine was very badly corroded and could not be used. Thus I had to make wooden supports that could in turn be fixed to the pallet. The biggest problem with this was that there was no common datum on the bottom of the drum housing, in effect the drum if placed onto a flat level surface could not stand upright. In order to obtain a level across the three mounting points, I turned the drum over onto its lid, ensuring that the lid opening catch was not touching the workbench surface. The height difference between the mounting points could then be determined and wooden planks and spacers cut to the appropriate length and thickness and attached, using the original mounting bolts and nuts (recuperated). These supports were in turn screwed to the 'carrier' planks which were parallel to the drum axis, so as to fit across the pallet, next to the bicycle. These two 'carrier' planks were slotted, two slots per plank, the slots coincided with the approximate centre line of planks on the main pallet and with four holes drilled therein. Securing bolts and washers secured the drum to the pallet.
Drainage of water from the drum was as with the pedal washing machine via gravity. I had established that once the redundant pump assembly had been removed from the bottom of the drum, a conventional vacuum cleaner hose would fit neatly over the exit port where the pump had been attached.
At this stage of the construction, I was still unsure as to how much additional bracing would be needed in order to hold the drum steady at the elevated speeds of spinning. As a provisional measure, I took advantage of four moulded stubs integral to the drum housing, these originally held the shock- absorbers. Down the centre of each stub I drilled a hole and then tapped it to 6mm. I then attached planks which spanned the pairs of stubs on each side of the drum housing using 6mm bolts.
Now the drum was fixed to the pallet, I could extend and attach the chain from the bicycle to the smallest gear of the cluster on the drum shaft. It is possible to ensure the chain is running straight between the two sets of gears simply by looking along the faces of the two gear sprockets (driving and driven). Optimum chain tension and alignment was attained by moving the drum assembly on its slotted mounting holes prior to tightening the mounting bolts.
STEP 6: Test Run
Once the bicycle and drum were connected, a quick pedal with the drum empty established that there were no problems with alignment and chain tension. So it was then time for the acid test.
Wet washing was transferred from the washing machine into the spin dryer and the lid closed. The starting load on the pedals was noticeably higher compared to the lower 1:1 gear ratio of the washing machine but it was not difficult to set the drum in motion. Slowly accelerating, it became apparent that for what seemed a relatively slow pedal speed, water was exiting rapidly from the drain tube. Accelerating further the water flow increased and then as the contents became drier, diminished. Timing my pedaling speed I determined that the drum spin speed was about 350 rpm which could be maintained for at least a couple of minutes until the water flow was nil. Letting the drum freewheel to a halt, the contents were examined and were definitely much drier, to the extent that no further water could be extracted when it was attempted to wring it by hand.
After using the spin dryer for several months I think we've established that the configuration works really well but the distribution of the wet load within the drum is crucial. Uneven loading results in shaking of the whole machine and pallet and it is often the case when the wet washing comprises just a few items. With a single large item though - Sue washed our feather duvet, the spin dryer was amazing.
STEP 7: Improvements
The first thing that would improve the spin dryer will be to obtain another top loading machine and keep the drum in its original housing. This would obviate the need of making elaborate supports to hold the drum level and steady.
Secondly I think that the drive to the drum should be direct i.e. not freewheel. This I believe will enable the 'cyclist' to rotate the drum in both directions at the start of the spin-cycle to distribute the wet contents evenly within the drum and thus prevent the need to stop spinning to even the load in the drum.
Hope you enjoyed this project and much as we do having non-drip washing! If you read this and found it interesting then share it with your friends on social media or suchlike. Please also feel free to ask questions, share tips and/or make comments.
You can also find all my films Youtube and also now on Odysee
Happy wash day pedaling!
Cheers,
Andy
LInks to my pallet articles:A Few Guidelines for Collecting Pallets
I thought it might be helpful if I shared my five rules to make it easier for you to obtain the basic material...read more
Pallets - The Low-down - Where, What and How.
So you've been round to your local big chain supermarket and they've told you all their pallets are reused. Well this maybe true for them but not for all pallets...read more
How to Dismantle Pallets for free Carpentry Wood
The first thing to do with your pallet when you’ve got it out of the car is look underneath it and see if the nails attaching the planks are visible...read more
17 Comments
grapenut 2 years ago
SIDE NOTE: I don't know if it still holds true today but around 16 years ago when front loaders were still pretty new in the states, I did some research that indicated that the key components of almost all known horizontal axis front loaders were from Germany. Maybe it was a patent rights thing at the time, idk.
Anyway, the top loading washers here stateside spin on a vertical axis. They typically require more water than a horizontal spinner and would be hard to find in many European urban areas ; but, when the (vertical axis) machine is stopped, and it is safe to do so, the load can be manually, and easily distributed evenly. If you can find a top loader (vertical axis), and switch to belt drive (to make the 90 from horizontal pedal power to vertical axis top loader) it may be an option. Otherwise it may be possible to put a front loader on it's side, so that it effectively becomes a top loader (for spinning). I have not worked out how to switch to belt drive and retain freewheel. Maybe the folks from UT can come up with an idea? Please excuse my unsolicited ideas and; Thanks again for the wonderful instructable. Best one I've seen this week.
Organikmechanic 2 years ago
I think that I will go for a braking system anyway, just for safety's sake, but I do like your idea of the 'stop/start' motion to redistribute the drum contents. I'll try and rig something up in the next few days.
The machine type you're describing as commonplace Stateside I am slightly familiar with in that my Mother had that kind of machine years ago but no spin facility, just a powered wringer running from the same motor. As I recall, the electric motor on this was vertical axis also, but I have seen this configuration with a horizontal axis motor which would be ideal for a bicycle. Just leave the rear wheel in place and run a drive belt from the tyreless wheel.
Thanks for reminding me we are living the dream. Yeah we opted out 21 years ago and frankly have enjoyed the challenge of adapting to a new country/language etc. It certainly is much more peaceful here and we can always get down to the beach for long walks and in the Summer the chance of a swim. Although it is a very popular vacation spot for the Parisians many of whom have second homes here we are still able to find room on the sands.
Once again I really appreciate your suggestions and will carry on with developments.
Kind regards from a slightly frosty Normandie, Andy.
I agree that your toploader, a design I was previously unfamiliar with, is a very robust design. And now that I think about it, it almost had to be that design, because as you mentioned it allows for a drum shaft and bearings on both sides of the drum; whereas the other popular European models you mentioned, could have a shaft with bearings on one side of the drum and allow for a door to open on the other. And thinking about how you obtained your machine, even though the body and frame were badly corroded, it seems the shafts and bearings held up well enough. In contrast, the other common design, with the shaft and bearing on one side of the drum and the door on the other, is almost always going to wear out the one-sided bearing long before things start rusting out.
"perhaps go for a pair of toe-clip cages on the pedals?"
My initial concern about a "foot slipping off the pedal" was really just a sort of generic, preliminary concern about; as an example: the foot slipping off and then the rider inadvertently becoming dismounted from the seat and getting tangled up in the pedals...depending how heavy the load is, I'm thinking some bad bruises might be a good outcome under such circumstances. Also, and I'm sure you have thought of all this...I was also concerned about a curious cat, dog, chicken, or child venturing too close to a direct drive pedal, or even a freewheeling drum. Though I think your drum is housed in a plastic, water catching shroud...
Every year here in the US a certain number of kids lose their arm when they open up the lid of our (still) popular top loaders, during the spin cycle, and not comprehending the forces of inertia, speed, and weight they stick their arm in, and some pant leg or towel corner gets wrapped around their forearm and it often twists things off between the elbow and shoulder. The newer washers have for many years now been required to have a braking mechanism which is triggered by opening the lid, however, these switches go bad (happened to our machine once, leaving the drum FULL of water and no way to drain, spin, wash, etc...) and even though the switches are pretty basic and very similar from one brand to the next, the mounting can be slightly different from one brand to the next; so the switches need to be special ordered. Prior to the internet someone would have to go to the local hardware or appliance center and pay a huge markup for them to order it; which also meant waiting for them to actually get it on order and then wait for it to arrive, etc... So, in that case what would often happen is a friend, neighbor, uncle, etc...would easily bypass the switch, allowing "hopelessly" distraught launderer to continue on with the washings. I think I know what you are thinking, but not to forget, I am talking about we Americans...I was 26 or 27 and I was in Romania needing to do laundry off the ship. There was no coin laundries in Constantia. Someone there offered to do my laundry at their facility at their home, and I was genuinely blown away when they showed me an ordinary bath tub as their laundry facility. We had an identical bathtub in almost every place I'd ever lived, and though we had sometimes filled the tub for reserve flushing water, incase of a water outage during severe storms, we had never had a water outage 'because of a storm', and it NEVER would have occurred to my American brain (or 95% of us at the time) to use a tub for washing clothes or linens. I have to say that our country is much more diversified now, and this most probably would not be such a strange idea for many of the folks in my current neighborhood.
For me, the ideal setup would be:
your machine/topload (horizontal) drum, with freewheel, with brake, and a couple other things I'll get to in a bit. Oh, and I am of course assuming that my original idea about using the brake as a means of achieving a more evenly distributed load is effective enough.
If the brake does not adequately help distribute the load, then my B plan would be:
To use a top loading vertical axis machine, or in your area one of the more common horizontal front loaders, turned on it's side to essentially function as a top loader, with freewheel, and a brake. With a top loading vertical axis machine, the load can be evenly distributed around all sides of the drum and there never needs to be an uneven load.
Before I go any further I also wanted to make a comment about the "toe-clip cages on the pedals." I think that as long as the seat is the right seat for you, and at the correct height, etc...then the toe-clips would probably work to keep your feet from sliding off a pedal; but I am concerned that if the bike has more than one user, and if the seat adjustment gets changed, and it is possible for one of the users to adjust the seat too high, then would it be possible for a foot to get stuck in the toe-clip, just enough to dislodge someone from the seat, resulting in a loss of balance entirely, and then injury from the rotating pedal, with or without the foot still inside the toe clip? I'm probably overthinking, but if I saw this, I would wanna try this thing out, never mind if I were a kid. So if some kid came along or someone with shorter legs, and they failed to lower the seat enough; could a foot get stuck in the toe-clips, etc...?
2 more ideas I would like to share:
1. Banana seat. Somehow the mention of these seats has always made my generation laugh. I had 2 bikes with banana seats growing up. They are longer seats, harder to fall off, and more comfortable. Another advantage being, for 2 users, the seat could be lowered to the appropriate height, and subsequent user with longer legs may be able to simply use the extra length of the seat to slide back a bit to accommodate the longer legs. Disadvantage; the vertical says on the rear of the seat could make height adjustment less convenient, if needed. (pictures coming)
2. 2 types of brakes: a. grip applied (using grip to overpower a weak spring that normally keeps the brake open, conventional bike brake). b. spring applied (using the grip to release a brake that is otherwise held tight by a relatively strong spring. similar variation used on large trucks with air-brakes; if ever there is a loss of air pressure, which is needed to apply the primary brakes, then the spring applied brakes take over as a backup. In this case if there is not a loss of air pressure then the air pressure pushes against the the springs in order to prevent the springs from braking. Anyway I was thinking this good be an interesting application for a similar braking system, with a fail-safe. Or if the fail safe worked well enough, maybe it could be the primary brake, with integrated fail-safe.
Once again. I really like this project of yours, and am so intrigued by the whole thing, French countryside/seaside, etc...hope all is well with you and yours
It's late here, so I think I'm going to add 3 or 4 pictures tomorrow to of the banana seat, and some of the US washers. Thanks again for everything.
Cheers
With respect to the weight distribution problem, I undertook a 'thought experiment' with this and concluded that as conventional machines don't have a 'stop/start' brake for this then the reason must be a simple one. Experimentation proved this to be so; by adding about 1 gallon of clean water immediately before starting the spin cycle, the garments can freely move to the drum perimeter before the water drains out and the load is much better balanced. As I said in the description, the draining of the drum is via gravity and not a pump. If I had some simple valve on this line to allow emptying of the drum only when the load feels sufficiently balanced then I am sure I could improve on this.
Once again, thanks for your feedback, I really appreciate it.
Cheers from Normandie, Andy.
Anyway, I had to unthread the adjustable feet and use those holes to mount the casters. The threads were metric, I believe M10 if memory serves...I originally tried every kind of SAE (imperial) bolt the size. The SAE bolt size that was closest was too big and wouldn't thread in very far; or maybe it was close enough to M10 but the SAE threads were never going to match with the metric. I did get one set of SAE bolt and threads to go in all the way, but I knew they weren't right, there was too much slop, and it seemed as though the threads were at risk of jumping if they were too snug or not snug enough; so I snugged them just a bit and left them temporarily. I finally determined with a thread gauge on one of the removed feet that the threads were definitely metric, and I suspect if Whirlpool, Maytag, and KitchenAid are using metric for the feet, on US washers, they may well be using them throughout.
Thanks for commenting once again. Cheers, Andy.
ledivam.com 2 years ago
By- https://www.facebook.com/macgaywer/
rc jedi 2 years ago
LeslieGeee 2 years ago
calienteyoga1 2 years ago
Don Barthel 2 years ago
