Make a VGA PRO (tm) Extender...
Intro: Make a VGA PRO (tm) Extender...
I am Matthew Enderle. I will write a through instructable on how to make one of these. Please go to Step 1 for the bill of materials.
STEP 1: Bill of Meterials.
You need to go to newark.com and get part of these items.
newark.com
Item # Type Cost in $ Quantity
16M3874 D-sub 15 pin 1.50 2
83K8228 Modular Connector 1.01 2
* 83F8733 Mini-case 1.47 2
*optional
or you can click this link to automatically add them...
|>Add Items to Cart<|
ADDITIONAL DETAILS
You will need wire. The perfect wire for this, believe it or not, is ethernet wire. The kind i like the best is the wire with many strings, not one solid wire. The solid wired ones, when they are bent too much, they break really easily.
I made one of these using old ports from 2 videocards, and 2 networkcards. You could use that instead of buying new parts.
---Please procied to step 3 for the Schematics and diagrams---
newark.com
*optional
|>Add Items to Cart<|
ADDITIONAL DETAILS
STEP 2: Schematics and Diagrams.
If the first picture is too confusing, use #2.
This is the text base version of it. First number is ethernet pin, and second is the VGA/hd15 pin.
1 - 14
2 - 13
3 - 3
4 - 7
5 - 2
6 - 5,8,10
7 - 4
8 - 6
*NOTICE ethernet pin "6" is indeed connected to all of the following pins - 5, 8, and 10. These are the R, G, B grounds.
1 - 14
2 - 13
3 - 3
4 - 7
5 - 2
6 - 5,8,10
7 - 4
8 - 6
STEP 3: Recieve Your Parts.
Less than a week i received all my parts from Newark. The pictures show what i received.
STEP 4: Tools Required.
You need to buy or get your tools.
You need:
1 Soldering Iron
1 thin solder spool
1 dremel - and a huge kit.
1 Hot glue gun
1 bottle of flux (solder paste)
You need:
1 Soldering Iron
1 thin solder spool
1 Hot glue gun
STEP 5: THIS IS THE START!!!
You need to open all the packages. The parts you will need out are the VGA and the project housing.
12 Comments
kroner 12 years ago
MatthewEnderle 12 years ago
excal2 12 years ago
How far did you extend your VGA with this method?
pwvandeursen 13 years ago
unkn0wn1 13 years ago
MatthewEnderle 13 years ago
mike_k11 13 years ago
thanx
Standerd colors if you make a cable are
wight orange
orange
white green
blue
white blue
green
white brown
brown
As long as both ends have the same wires in the same pins you'll be good.
rivera82falcon 13 years ago
