Introduction: Deleteme
Step 1: Finished Projector!
That's all!
The finished Projector will look like the first photo.
And projecting a video will look like the second photo(it looks a little bit worse than it is because i took the photo in the dark).
If you liked this Project vote on it, in the Camera & Photo Skills Challenge and in the Green Living & Technology Chalenge! Thanks
Green Living & Technology Challenge
32 Comments
6 years ago
Is there a way of double inverting the image so it flips back to the right way up using two glasses?
7 years ago on Introduction
Can anyone please tell me the glass power or pecular magnification glass type.I have bought a 4x magnification glass with 60mm wide and does as per the instructions,but only a blur image exactly there is only a blurred form of light and if i do with 6x glass with 2.2 cm radius i can see it only a small image.NOTE the the both lens comes on the handle of the same as a combo.Please someone help me to sort out,what is the problem.
8 years ago
had to figure a way with the small box and magnifying glass I had, but I impressed with a "first try"
what kind of magnifying glass did you use?
Reply 8 years ago
a standard glass from a set of "helping hands"
I tried this but I only get a white light image. I tried focusing back and forth but nothing happens. What magnifying glass did you use? I think it's the problem. When I first tried it, I use my moms eye glasses (which is concave obviously) and I see some flipped blurry image with colors slightly visible so I thought It would really work If I buy a real magnifying glass but It does not work so I'm thinking that the magnifying glass needed should be concave.
8 years ago
Can I play games while projecting
While your phone is inside a box?
9 years ago
HEY!!!! I KNOW YOU, you're from that you tube channel called house hold hacker
9 years ago
How do you do that with the accelerometer?
9 years ago
Been looking for a long time can't wait Tory thx
10 years ago on Introduction
Credit the source of your content. This is quite obviously stolen.
i tried this project a hundred time but it does not work I am sure I follow your structure step by step but the result was like a normal torch please help because I am so interested>>>
anther question is if I want use a mirror to improve the quality should I use a normal mirror or a Convex mirror or .....?????
thanks so much
if i wanted to use my laptop, would this system work? assuming that i used a box big enough to put my laptop in. and maybe a bigger magnifying glass.
11 years ago on Introduction
talk to me on this web site
looks great thanks
i wonder if i add a bulb if it will be brighter
11 years ago on Step 1
I tried this projector with a condenser lens {picked from a film still camera} ,so that i get a small and dim image
Interesting project, but don't you need to focus the image? Does it come out clear enough? How big is the image and how far can you project it?
Reply 11 years ago on Introduction
To focus the image I simply move the box(projector) forward, or backwards. If you put the box to far from the wall, the image will get a little bit bigger but blurred. The image is a little bit dark compared to a real projector, but for 3$ what could we ask more? Thanks
