Make a Deer Feeder
Intro: Make a Deer Feeder
STEP 1: Materials
The materials that are needed are
1) 2 inch diameter (smaller sizes will also work) pvc pipe (any length should work)
2) Hacksaw or PVC cutter
3) metal wire, rope, or string
4) two 2 inch pvc pipe caps
5) pvc glue
5) tape measure
6) marker
7) horse feed or corn
8) tree or post
STEP 2: Cut Pvc Pipe
Cut your 2 inch diameter pvc pipe to your desired length. Measure the pipe to the length you want and mark with a marker. Use the hacksaw to cut through the pipe at the line you marked.
I cut mine to about 30.5 inches.
STEP 3: Glue on a Cap
STEP 4: Cut the Opening
Next, cut diagonally from about an inch above the original cut until meeting the first cut. You should now remove the wedge shape piece of pipe. This serves as the opening for the food to fall out. This is difficult to explain so look at the pictures if you are confused.
STEP 5: Put on Tree or Post
STEP 6: Food
You are now done with the deer feeder. This feeder could also be used for ducks, geese, chickens, racoons, opussums or any other wildlife.
11 Comments
KKT1 8 years ago
ive made lots of these and mine were very similar except for top I used a screw on end cap and the bottom I used a "u" piece glued on so that the whole thing looked like a giant candy cane...it was gravity fed so as the deer would eat the feed from the top of the "u" it would simply fill back up. I also added a "screw on" end cap on the "u" end as well . made for easy transporting to the woods..
jking vincent 12 years ago
1flyby1 14 years ago
biffula 12 years ago
Hoosiergoober 13 years ago
ramatern 13 years ago
EncasedDeath 13 years ago
carlos66ba 14 years ago
EncasedDeath 14 years ago
Kozz 14 years ago
Particularly in Wisconsin and during the hunting seasons there are limits to the quantity of food, the type of feeder (gravity-fed) and your location (such as CWD eradication zones) and vicinity to roads or buildings.
Additionally depending on what's in the feeder, it's possible a black bear may get impatient and attempt to tear the entire pipe from the tree. I've seen black bears tear down multiple birdfeeders containing sunflower and thistle (if you can believe it, he must have been hungry).
