Make a Permanent-marker-remover!
Intro: Make a Permanent-marker-remover!
This instructable will show you how to make a permanent-marker-remover out of an empty text marker and some nail-polish remover.
With the power of nail-polish remover and the precision of a text marker, you can easily clean away any small permanent-marker stain!
STEP 1: What You Need
For this project you'll need:
- some nail polish remover
- an (empty) text marker
- a sharp knife or a hacksaw
- some heavy-duty tape (electrical tape works fine)
- a tissue or paper towel
STEP 2: Draining the Text Marker
If your text marker isn't fully empty, it is highly recommended to drain it first.
To do this simply take a paper towel or tissue and wrap it around the tip of your text marker.
Let it sit overnight and then feel the tip to see if it's still moist.
STEP 3: Filling Up the Cartiridge
- Now take your knife/hacksaw and cut the back piece of your textmarker off so you have access to the fabric ink cartridge.
- Then take your nail-polish remover and slowly fill up the cartridge. Make sure to do this over a sink because the nail-polish remover will leak out the tip if the cartridge is full.
- After the cartridge is full, tape the end back on with some heavy-duty tape. It must be heavy-duty or else the vapors of the nail-polish remover will leak out of the end of the marker.
STEP 4: Finished!
Now you've finished your permanent-marker-remover!
Here's how you do it:
- Select a mark (made with a permanent marker) on a shiny surface (I works best on ceramic, metal & hard plastics, on soft plastics the nail-polish remover will damage the plastic when applied)
- Take your permanent-marker-remover and color over the stain with the flat side of the tip (this will ensure that enough nail-polish remover is flowing on the mark)
- Now take a tissue/paper towel and wipe the area clean
- If the mark is still there, repeat 2. and 3.
- When the mark is gone use a clean part of the tissue/paper towel and wipe the tip clean (note that you won't be able to get the tip totally clean but this won't affect anything)
- You have successfully removed a mark made with permanent marker!
Make sure to regularly fill up your permanent-marker remover. To do this simply hold the tip of your permanent-marker remover in nail-polish remover for a minute or so.
Don't forget to comment, rate and make&enjoy your own permanent-marker-remover!
Candymanproductions
16 Comments
Seth C 7 years ago
Or if its a shiny surface (whiteboard, ceramic, metal & hard plastics etc) you could just scribble over the mark with a white board (non-permanent) marker and wipe off while it's still wet.
craftyv 7 years ago
Bought a pair of leather shoes at a charity shop and they had written the price in permanent marker on the sole (leather) Still trying to remove it. Note: Poor people don't mind walking around with their poverty on display, do they?
JXH7233 7 years ago
Wouldn't straight acetone with a small cloth or Q-tip be much easier?? Naptha works too....
rwadeg 7 years ago
Fill it with Goof Off grafitti remover
pmarx-thompson 12 years ago
sbell16 12 years ago
Monoclecat 12 years ago
jcheng3 12 years ago
erict 12 years ago
TheHawkeye 12 years ago
tinstructable 12 years ago
King Julien 12 years ago
killbox 12 years ago
and now I know one thing to try out in them! may try making another one full of goof-off or goo-gone.
