Make a Simple Battery Discharger for NiCad or NiMH Battery Packs.
Intro: Make a Simple Battery Discharger for NiCad or NiMH Battery Packs.
This instructable will show you how to make a simple discharger for your NiCad or NiMH battery packs for Airsoft AEG's or RC cars, boats, planes, whatever. Draining your NiCad battery packs is an important step in preserving the life of the battery, since NiCad's suffer from whats known as the memory effect. The memory effect is when a NiCad isn't fully charged on its first cycle, then depleted, and recharged again. However, it will not achieve a full charge because it's cells have adjusted to half capacity, or memorized half capacity. NiMH pack do not suffer from the memory effect and do not require regular darining, but if you plan on storing one for an extended period of time, you may wish to do so.
The design is not mine though, it is borrowed from this one here and here. I didn't see the point in paying $5 plus the shipping for something I could easily make for less that amount.
I bought all the supplies(2 12v bulbs, heatshrink tubing and tape) at Wal-Mart for a total of $5.63.
Price list:
2 Pack 12v Bulbs - $2.78
Heat Shrink Tubing - $1.96
Tape(you probably have it, but I happened to have ran out)-$.47
You may be able get spend less at other stores or if you already have some or all of the materials.
Price list:
STEP 1: Materials and Tools.
You will need the following...
1. Soldering Iron, and of course solder.
2. Electrical Tape
3. Heat Shrink Tubing
4. 2 12v Light bulbs, used for car tail lights and backup signals.
5. 1 Tamiya connector. I used a smaller one from an old charger that fits my battery. Yours may depend on the connector size of your battery.
6. Some 16 gauge wire or similar.
NOTE: Coffee pot not required :).
2. Electrical Tape
STEP 2: Step One.
Prepare the Tamiya connector to be joined to lead wires.
Since I harvested my connector from an old charger, I had to graft the 16g wired to it. If you do similar, you will need to do what I did here. If you get your connector some where else with wires already attached, you can skip ahead to the next step.
Ok, strip the coating off the two wires on your tamiya connector. MAKE SURE THE POLARITY IS RIGHT SO IT WILL MATCH UP WITH YOUR BATTERY. Ok, that didn't need to be in caps, but is is important that they match up. Usually the round post on the connector is the positive and the squared one the negative. If you use red and black, join them accordingly.
All I did was strip the wires and twist them together, put a little electrical tape over one connection, then slipped a piece of heat shrik tubing over it and then shrunk it. You can solder the connections if you wish.
Sorry about the yellow tinge, I had to take the pictures in my kitchen cause I was to lazy to clear my computer desk, and If I used the flash up close it ruined the picture due to the white counter top.
STEP 3: Step Two.
Ok, the polarity on these bulbs really didn't matter, they worked both ways. Yours may be different, but check anyway with a 9v or with your assembled part from the prior steps.
Anyway, you need to solder the positive(or negative whatever floats your goat,lol)to the bulb. The ones I used had two contacts on the bottom that where conveniently made of solder. All I did was melt them, stick the wire in it, and then solder some more on for good measure.
I found that the easiest way to do this by taking a water bottle, or soda bottle and sticking the bulb on top and holding it in place with a piece of tape. It makes the whole process of soldering to the bottom of the bulbs a heck of a lot easier!
STEP 4: Step Three.
Unfortunately, I accidentally deleted the picture I made for this step, but you can clearly make it out in the one below.
Ok, take the other bulb and lay it opposite to the first bulb. You can use some tape to hold the two together. Put the negative wire in between the the bulbs and solder it in place. This was the hardest part of the job for me because the solder wasn't sticking to one side of the bulb, so I had to make it as best as I could and hold it together with tape. I suck at soldering, but if your good at it, you shouldn't have any problems.
STEP 5: Step Four.
Now, you need to complete the circuit. Cut a piece of wire long enough to reach around to the bottom of the other bulb. Make sure you strip enough coating off to make it easy to solder. I was able to slip one end of the wire under the first connection on the first bulb and fold the wire over and solder it in place(sorry no pic of that, got deleted). Or just do whatever is easiest for you.
After you secure it to the first bulb, flip it over and solder it to the second bulb.
Trim any excess, and wrap the middle in electrical tape.
STEP 6: Test It Out.
Connect your battery pack to the discharger and make sure it lights up. If your using double filament bulbs like I did, make sure both are lit.
Congratulations, that's it, your done!
You can add more bulbs to the circuit if you have a larger capacity battery. Mine is a 8.4v 1100 mah battery.
Oh, and be very careful where you put this thing when its plugged in, the bulbs get very hot!!!
39 Comments
stavart 10 years ago
Can you use this method to totally discharge Lipos(that aren't good anymore), for safe disposal?
hansonsux 14 years ago
shannonlove 11 years ago
m1sterb0b 13 years ago
hansonsux 11 years ago
* Why people still continue to perpetuate the "memory myth" is beyond astounding. In doing so, people will heavily deeply discharge their cells believing their actions will make their cells healthier, but in reality they are doing more harm than good in the process.
m1sterb0b 11 years ago
Amperis 12 years ago
de0509 12 years ago
rcisneros 13 years ago
Macworldwizardz 13 years ago
shad0w88 14 years ago
i've done this is it right?..
i plugged this into 7.2v battery and it wouldn't light up??
S1L3N7 SWAT 14 years ago
arvindhimalayan 14 years ago
petederidder 15 years ago
fwjs28 15 years ago
Derin 14 years ago
fwjs28 14 years ago
fwjs28 14 years ago
S1L3N7 SWAT 15 years ago
