Louder Volume on Android Asus Transformer
Intro: Louder Volume on Android Asus Transformer
Our great Asus Eeepad Transforme is proberly one of the best tablets right now and it work perfect. There is only one small problem. The internal speakersound is not the best. The problem is, that the small speakers is placed in a the wrong way, turning against the screen and without enough free space, so all the sound is getting strangle !
My instruction show how you place the speaker in a more correct way and how to make speaker grill with real holes, for a louder sound
FIRST: Please visit those sites, that shows step by step, how you open the Transformer TF101 for working with the hardware inside.
TEXT : http://www.techrepublic.com/blog/itdojo/asus-eee-pad-transformer-teardown-convoluted-but-3g-ready-internal-design/2833?tag=content;siu-container
PHOTOS: http://www.techrepublic.com/photos/cracking-open-the-asus-eee-pad-transformer-tf101/6270147?seq=2&tag=siu-container
Please notice
- Open case: the Transformer has two external screws. The screws hold the Transformer’s front bezel in place–not the back cover. Once you remove the bezel, there are several more screws holding the back cover in place. Opening the Transformer’s case is not difficult.
- Standard screws: Asus did not use any tamper-resistant screws on the Transformer. The unit two external screws have Torx T5 heads and all the external screws have Phillips #000 heads.
- Battery can be replaced (but not easily): The 3300 mAh, 24Wh Li-Polymer battery can be replaced, and you don’t need to remove the motherboard to do so. You will however, need to disconnect several cables, remove a few pieces of tape, and pry the battery loose from the internal frame. Asus could have made the process more complicated, but not much.
STEP 1: Speaker Grill
Locate the area where the back of the speaker is placed. Clean the area where you shall drill. It shall be flat and clean
STEP 2: Make Speakergrill Holes
Use some kind of stencil to make good looking holes. I have taken a metalgrill from a old PC speaker and cut it in the right size. Use lot of tape to fix it in place. Drill from inside. The drill and holes in the stencil should be the same size. I have chosen 6 X 23 millimetre as the grill area, that is near the same size of the inside speaker, but if you like another design its not a problem. Use a permanent marker to colour the area where you want to drill, then its more easy to see where to drill.
STEP 3: Clean Holes
Remove the stencil and use a sharp knife to clean the inside area. Use a bigger drill to clean outsite holes. Be very carefully in this step, for best result.
STEP 4: Protect Speaker With Textil
Use small pieces of black textile to and protect the inside speaker and darkness the holes. Fix it with a few drops of glue
STEP 5: Turn Around the Speaker
As you can see is the speaker turning against the screen original (!) which seem to be very strange..
Take out the speaker and turn it around , You have to use a sharp knife to change to a new angel in plastic on backside of the speaker . It can take some time to do it, but are not difficult
Do the same with the other site... Be careful with the small wires.
TIPS
There is a known small problem with low sound level in the left speaker. The amplifier in Asus Tranformer is very weak and therefore thicker wires to the left speaker will could make them sound louder.
Remember NOT to use any heat or soldering near or on the speaker itself The ultrafine copper wire inside the speaker will smelt!. Cut the wire minimum 10-15 millimetre from the speaker input and use those as terminal, when you soldering
STEP 6: Congratulation
Congratulation
You are now near finish with the project.
As you can see, the speaker is placed in the new directions and will now could play load and clear without any disturb. When you hold the tablet in landscape mode, the inside of your hand will be like a trumpet, that will amplified the sound and direct it to your ears.
Reverse tear down and enjoy the new loud sound from our great Asus Transformer
18 Comments
CCTV Pati 7 years ago
Pemasangan CCTV
Nice Reading ! Thank You
Website : https://cctvpati.com
lalsingh 8 years ago
<a href="http://www.stepup.heightincreaser.in">Step Up Height Increaser</a> is a 100% Ayurvedic Body Growth System.
Step Up offers Amazing Results! After using StepUp Height Increaser you will see new confidence in yourself.
Step Up Height Increaser is a revolutionary step by step total growth system, It gives the required nutrients to
the body that help to increase height & also lead to total body growth.
masanasya 8 years ago
thanks for the info you provide, your article very inspiring, I don't have feel bored will reading until the last paragraph :), I also have a blog about tourism place, where I review various Indonesian Travel Destination thanks hope will give more information.
muktasir 8 years ago
Jasa SEO
- It is in reality a great and useful piece of information. I am glad
that you shared this helpful info with us. Please keep us informed like
this. Thanks for sharing.
website: https://www.distributorseo.co.id
webseobuy123 8 years ago
We are really grateful for your blog post. You will find a lot of approaches after visiting your post. Great work.
http://www.webseobuy.com/cms.php?id=5
pnavarro1 9 years ago
I made it! Running KatKiss Lollipop.
Dark_Falcon1 9 years ago
Thanks for sharing this idea!
I've just made it, I didn't make nice holes, but you can definitely hear louder sound.
It still is not as loud as I hoped for, but you can at least hear the sound from the speakers again.
I run katkiss 4.4.4 @ TF101 with kitkatt app that amplifies sound.
Someday I'll try the part with the thicker wires, but for now I'm glad I don't need a headset connected :)
HermanA1 9 years ago
Thanks for sharing excellent information's. Your web-site is very cool. I'm impressed by the details that you have on this web site. It reveals how nicely you perceive this subject. Bookmarked this web page, will come back for extra articles. Buy Essay | Buy Custom Essay
MRedu 12 years ago
DocHammer 12 years ago
For something less expensive at $55.00 go with the Creative D100 Portable speaker. http://www.google.com/products/catalog?rls=com.microsoft:en-us:IE-SearchBox&oe=&q=portable+bluetooth+speakers&um=1&ie=UTF-8&tbm=shop&cid=4678685648185526059&sa=X&ei=DbyBTtO1OvLF0AGej6X2CA&ved=0CJUBEPMCMAM#
And Tenqa has a bluetooth speaker for less than $27.00. http://www.tenqa.com/sp99-bluetooth-speaker.php
I think spending a few bucks on a better speaker system would go a long way to providing better sound and would also save you the time, effort and peace of mind of disqualifying your warranty.
Traumbrecher 12 years ago
DrHoppe 12 years ago
WakeUpWolfgang 12 years ago
Bulgarien 12 years ago
I had to say no - you need holes, but as you see can no one will even notice the mod. If you dont like my version you can make you own grilldesign. Second, the tablet will be outdated very fast (six month) so the secondhand price will be very low, with and without the mod, so I can not see any reason not to enjoy better and louder sound right now.
Greetings :-)
sharpfork 12 years ago
godfish 12 years ago
Thanks for posting, Great Idea...
thearchitect 12 years ago
