Make a Poweful Railgun!
Intro: Make a Poweful Railgun!
Removed.Removed.
Removed.Removed.
Removed.Removed.
Removed.Removed.
Removed.Removed.
STEP 1: Obtain Parts
Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed. Removed.
STEP 2: Assemble the Enclosure
STEP 3: Make the Bank
STEP 4: Make the Charger
STEP 5:
147 Comments
InfinityHex 8 years ago
Rileyd5 7 years ago
it depends on your skill, i know this is probably way past time but i think this may help. this project is obviously done at your own risk. but if you want to build one you just have to get a few things straightened out, you need the voltage and amperage to power this which is probably a project of its own if you don't have access to the power supply beefy enough to handle it. second you need the proper frame and rails. the rails are ideally tempered aluminum or copper. (i've tried using copper and it tends to start warping and getting melted after 5 or so shots and have to be adjusted after that.) and if you have access to 3D printer(s) it would be ideal to print parts of the frame to avoid arcing and potential for shocking yourself or bystanders if they are near you or the device. Third you need the correct projectile and capacitors. 600 volts is quite a bit over kill and 300 is also a little much as it sometimes tends to arc through the firing mechanism and possible the rails depending of the size of the gap between them (when i built mine i used two servos from rc cars, one to put the aluminum bolt into firing position and a second beefier one to actually fling it fast enough into the rails then have the rails take over from there.) and then there's the bolt I've tried steel .308 bullets copper and then i ended up milling them using the shop in my school out of aluminum about 1/4 of an inch in diameter at the fattest but still "bulet" shaped. And to all the people saying it's impossible for a high schooler to build these... well i built mine when i was thirteen with little to no help from others except my uncle loaning me $75 bucks to buy three of the caps. if you are really determined use as much scrap and salvaged parts as you can it keeps cost way down and the parts you have to buy at a minimum, i will attach pictures of the rifle when i dig it out of my families storage shed sometime this month or so.
CadeConnelly 6 years ago
So I got ahold of sixteen 400v 150uf capacitors, I plan to use a "hot rail" design like the one here. Should I go ahead and purchase a couple more farads worth of capacitors? Also, I have designed a circuit to charge from 120v ac using a transformer (I will rewrap an old microwave transformer with 12:40 turns), and four diodes to rectify the current. My problem is that I am not sure what gauge wire I need to have for the transformer and what the diodes need to be rated for. I know that I at least need them to be rated for 400v, but I am unsure of what amperages this will put through the different components of my circuit. I have heard of putting a limiting resistor on the charging circuit to reduce the amperage, but I am not sure what to use if I do. I only know enough right now to do something stupid, so pointers from anyone who better understands circuits would be much appreciated.
_atlas 7 years ago
NO.
Snook-catcher 7 years ago
Based MbekeO 8 years ago
No. Do NOT do this project. Find something simpler, cheaper, and safer. In order to build this you have to know what you are doing. Which means you have to know a lot about electricity, safety, and engineering. It is expensive and would take a while for a high schooler to build. It is also extremely dangerous. It is several thousand volts which can easily kill you. This is more a project for someone in college who understands this stuff. And no, you cannot use a wall socket. House circuits are normally around 140 volts, which is not nearly enough to power this.
Robochicken 7 years ago
IsaiahC14 7 years ago
BluzD 8 years ago
Spencer10000 7 years ago
is it possible to make it holdable, for example, a plastic box, if so, how thick should the plastic be?
Rileyd5 7 years ago
yes, but your going to have to put in some work for it to fit into something portable
neil137 8 years ago
sorry im not sure how to ask questions on this site but it seems to be the place with people in the know.
i have several thousand dollars and a few months on my hands. i want a railgun. i dont mean the weak ones everyone else has. i want one that
rivals a rifle in speed and could do some seriious damage. could anyone point me to what parts to order from online?
or any tips to wiring and assembly? i have friends with cnc equipment and plenty of spare metal so it's not an issue, i just need some basic instructions
on how to get started and what speeds would be possible. if i have to incoporate a backpack too that's fine. i just want to put solid proof out there
that it's possible with todays tech. thank you.
lapince 8 years ago
BenderSanchez 8 years ago
The link in step 4 is spoilt just for your information.
Hobos_Bazooka 11 years ago
Is the capacitors in series or parallel
Thanks would really like to know
KyleV1 8 years ago
GreenD 14 years ago
I plan to make a smaller hand held one using the small 350 volt, 330 uF capacitors. I like this idea though. Have you experimentedwith lower voltages?
WillR10 8 years ago
Also, lower voltage = higher ohms = power loss to heat, so that's swapped logic. (That's why longer electric runs use higher voltages)
I agree with the plasma though; you can see energy being dispersed in directions other than forward. Hard to say how much is friction, and how much is electrical heat.. could try with a more conductive and/or more heat resistant material.. and I would think a longer, thinner projectile would accelerate more easily. (Maybe even with a point at the nose)
