Make Your Own Sanding Mop
Intro: Make Your Own Sanding Mop
I made this sanding mop for my drillpress and it works great !
You can use it for sanding small projects and to made sharp edges smooth.
Hope you injoy it
STEP 1: What You Need:
1. Abrasive cloth or old beltsander belts
2. Piece of 6 mm plywood
3. Clamps
4. Nuts and Bolts and washers M12
5. Scrollsaw / jigsaw
6. Masking tape
34 Comments
krysal 2 years ago
mang57 4 years ago
lindas10 7 years ago
What genius!
blkadder 7 years ago
An excellent project I have to say. I am getting ready to put one of these on my drill press, and I may make one for my bench grinder. Thanks for the great idea.
johnrhaney 7 years ago
I finally made a mop of your design to help me remove old finish from an old child's rocker I am restoring for my granddaughter. I initially used 120 grit. After reviewing your video, I'm going to make a 2nd one using 80 grit. Great addition to shop. Thanx.
rjcullis 8 years ago
Really good and it lets you make one for whatever grit you like.
buck2217 8 years ago
Great Idea shall have to give this a go
hegure_ryu 8 years ago
got to save this idea for the wood/workshop hacks
Ray.Meloury 9 years ago
hboom 9 years ago
I used a lock nuts to prevent that
hboom 9 years ago
I have my first sanding mop for many years... and never had the problem of a loosning nut.... Or use some CA glue to lock the nuts. And use a heatgun to loose them again.
kakashibatosi 9 years ago
Couldn't you use whatever nut and threaded rod you want, just flip it over so that the orientation works in your favor?
I didn't think it all the way through, you're right.
MichaelAtOz 9 years ago
You could use finer grades on one end (ie top/bottom) and course on the other.
grayl 9 years ago
How many jigsaw blades did you wear out by cutting the sandwiched sandpaper strips with it ;-)
hboom 9 years ago
To many :-) but I used at the end some blades for metal cutting.
vincent7520 9 years ago
simple and clever. Just like an instructable should be.
But I don't see why the rod should be filed ?
Perhaps so that while the sander is in use the threads wont get worn down and come loose. Or maybe the threads could damage the chuck. Might even be just for aesthetics. Good question.
