IPhone Locking Wrist Strap
Introduction: IPhone Locking Wrist Strap
About: Electrical Engineer | Woodworker | Robot Builder | Maker | Fixer
Imagine that you are taking a picture on a bridge with your iPhone. You drop it and you are out $200. You have three choices to prevent this from happening. 1, don't take pictures on bridges. 2, put down $15 for a danglet http://www.collinsamerica.com/page4/page4.html Or 3, you could make your own wrist strap for less.
Step 1: Getting All the Stuff
All you realy need is an iPod locking dock connector, it needs to be the locking kind (I found one at a computer hardwear store for $3) or if you have one just laying around collecting dust you can use that. You will also need a wrist band ( I used one of the old wii mote straps. Plus it tightens around your wrist so it doesn't fall off). Tools that you will need include a drill, drill bits, and wire cutters.
Step 2: Cutting the Cord
the first thing that you need to do is cut the cable from the dock connecter. cut the wire off just after the rubber part at the end of the connecter. (its easier to remove this rubber part after yo cut the cable)
Step 3: Drilling a Hole
Next, drill a hole about 3-5 mm (use your judgment) away from the bottom of the connecter (side without logo or words). the hole should be a little smaller that double the size of the wrist strap that you are going to be using. be careful when drilling because you will be drilling through plastic and the metal that is inside of the connector. also be sure to use needle nose pliers to get all the wiring out. if you dont you risk the chance that the wires will touch and drain your battery. (you will know this if your ipod gets really hot at the bottom)
Step 4: Finishing Touches
This next step is optional but makes it look better. Round off the edges with a file. now you can insert the wrist strap and connect to you ipod / iphone.
Be the First to Share
    • Tiny Things Speed Challenge
    • Made with Math Contest
    • Hide It Challenge
      Hide It Challenge
    9 Comments
    yaly
    yaly
    8 years ago on Step 4
    we need a solution for iPhone/iPod-touch 5
    GTBlogger
    GTBlogger
    11 years ago on Introduction
     Great idea but not very secure...  I found a better case with a wrist strap @
     www.computingreality.com/iStrap/
    check it out....
    PainTrane
    PainTrane
    12 years ago on Introduction
    Great idea, but since you have chop up your USB cable it would be better cut it, add an RJ11 jack, then add an RJ11 plug to the other side so you could re-attach your USB cable and still use it.
    elliot81
    elliot81
    great idea! how do you know if its 'the locking kind?'
    geekazoid
    geekazoid
    Nice 'ible, so you really found a dock connecter for three bucks? thats incredible, their about nine times as expensive at the apple store.
    invisiblelight386
    invisiblelight386
    Reply 12 years ago on Introduction
    yep, there's this computer store in the mall in my town and it has old cables and other used computer stuff.
    carlos66ba
    carlos66ba
    Cool idea, but 1) Make sure you get a "locking" connector (the ones from Apple don't!!!!) 2) Would this be strong enough to hold it in place securely? (I'd hate to have my $400 toy destroyed...)
    invisiblelight386
    invisiblelight386
    on #1, all the new apple cable don't lock, but all the old ones should lock On #2, i've tested this thing in many ways and i was able to twirl the thing around pretty good, so if your not launching the thing at the TV (like a wii mote) i think you should be fine
