Makeshift Breadboard Multimeter Probe
Intro: Makeshift Breadboard Multimeter Probe
Have you ever been going along building a circuit on a breadboard, and suddenly, you need to check something with the multimeter, but your good probes are nowhere to be found, and your backups are too large to fit?
This instructable will go through how to make a standard 1/4W carbon film resistor into a cheap probe adapter for use with breadboards.
STEP 1: Gather Parts.
This instructable is fairly simple, and only requires four items.
A generic 1/4W carbon film resistor (the most common type. If you are unsure of your resistor type, its probably this)
Some needlenose pliers.
A multimeter.
A breadboard
A multimeter.
A breadboard
STEP 2: Start Crushing
First, you need to remove the paint that is covering the outside of the resistor. You don't need to get all of it, just the on the two wider sections. This paint holds the leads in place against the resistor itself.
Try to get as much as you can, because the less you have left, the easier step 3 will be.
STEP 3: Pull
This step is fairly simple, just pull on both leads until they separate from the central resistor portion. Some resistors are easier to pull apart than others, but if you work at it enough, it should separate.
STEP 4: Use
Thats it! Now you have two probe extenders for your multimeter, for under a quarter USD (if you paid more, you seriously need to reconsider where you buy your electronic parts, not even Radio Shack is that high).
Alternative use:
If you wanted to, you could use this for testing more finished circuits as well. The leads are straight off of a resistor, so they can easily be soldered into a circuit to create a test point, for probing into tight spots that you frequently need to access.
Alternative use:
14 Comments
njmalhq 5 years ago
buh rill yunt
russ_hensel 9 years ago
Just a note to let you know I have added this ( a year ago ) to the instructable:
Comprehensive Guide to Electronic Breadboards: A Meta Instructable
>> https://www.instructables.com/id/Comprehensive-Gui...
Take a look at a bunch of ideas for using breadboards.
the_don125 9 years ago
Glad to hear you thought it was useful!
omni96 10 years ago
vishalapr 12 years ago
everestx 13 years ago
Using Female Molex pin from an ATX connector (could use a 12v fan, or whatever) I soldered that to an individual pin from a pin header.
The nice thing its, the leads from my meter stay in the molex pin due to the design. Wrapped it up with heatshrink and it's great. If I ever have a chance to post it, I'll be sure to thank you again!
fallenspirit123 15 years ago
Unit042 15 years ago
the_don125 15 years ago
Brian Henderson 16 years ago
burzvingion 16 years ago
GorillazMiko 16 years ago
