Introduction: Makeup or Cosplay Pin Up Zombie
I WILL BE GIVING YAL A QUICK SLIDE OF STEPS TO GET THOS AMAZING PINUP LOOK
I use mehron paradise palette pictured above. you will need purple Elmer's glue stick ,moisturizer ,settibg powder, detail paint brushes. A wig mine from amazon.. And white contacts mine r from rainbow Station.
Step 1: Makeup or Cosplay Pin Up Zombie
First thing I need to moisturize your face. I use Neutrogena. Then apply a layer of primer. The primer helps give ur face a smoother look. To get started the fist step is to apply Elmer's stick to your eye brows. Then add a layer of the airspun o er the wet glue carefully. You want to make sure the Glue is completely dry then add another layer. Repeat until your eyebrows are gone. Next thing you wNna do is draw the outline of your artwork. As pictured. It don't have to be perfect but its just to give u separation. To paint different colors and guide you.
Step 2: Makeup or Cosplay Pin Up Zombie
The biggest part is all the little details. So I always start with my base coat. Its the largest area to be painted. After that start filling in all the little designs. U wanna add a flat coat of pant and let dry COMOLETELY then go back over it until desired colors. ONCE U GET THE PAINT DONE TAKE EYES SHAFOW mx paint. Along the black u should shade with a dark brown or black just a thin line. Some places you will use different cokor shade. Referr to picture to see where shade goes. Thats really it besides finding the perfect wig for it. And applying the contacts. Make sure to be careful the them they keep them wet. Hopefully this will a surprise a good instructive.
Halloween Contest
2 Comments
2 years ago
Great details!
Your current cover image is the photo of the makeup kit - I think using the 2nd image in your intro (of the finished results) would help get more views if you put that as your cover image instead. Just a tip! : )
Reply 2 years ago
Thank you
