Making Mycelium
Intro: Making Mycelium
I am interested in bio materials that can return to the earth to support a circular economy. This project is the start of a larger project that will look at home made tools and products using waste food and bio materials to engage people to understand more about the product journey of the items they have in their home, ultimately reducing their consumption and impact on the environment.
Mycelium is the reproduction part of a fungus, consisting of a mass of branching, thread-like hyphae.
Mycelium is a fast growing organism and one of its primary uses is to decompose organic compounds. Petroleum products and some pesticides are organic molecules as they are built on a carbon structure, so they can be a potential carbon source for mycelium. This means it has the potential to consume such pollutants from their environment, (unless the chemicals are toxic to the fungus) which is a great potential for the circular economy to reduce the impact of plastics on the environment. As part of my research I will continue experimenting with the potential of this material to make a big difference to the material world.
This instructable guides you to making a material that is open for experimentation, it is not an end product. Get creative, and share your results.
You will need:
A sealable container - a glass tupperware is perfect
Corrugated cardboard
mushroom with a large base - I used King Oyster mushrooms
A scalpel or small knife
A dark place to store - a bucket is useful
STEP 1: Prepare the Growing Environment
Cut the cardboard into pieces that fit well into the container.
Stack them up inside and fill with water, you may need to weight them down so they are fully immersed under the water. Soak for 20-30 minutes so the layers of the cardboard will separate easily.
Drain then separate the layers so you have sheets of corrugated layers and sheets of flat card.
STEP 2: Cut Pieces of Mushroom
Take your mushroom and scalpel to cut tiny slices of the base. Only use the base as this is the reproduction part which will grow within the cardboard.
The third picture gives you a sense of scale to guide you with the size of each piece, make sure they are thin layers.
This will take you a while. I will be experimenting with using a food blender to see if this process can be sped up and if it effects the growth of mycelium.
STEP 3: Add the Layers
Add a layer of cardboard to the bottom of the container, as you form the layers you need to have a corrugated sheet and a flat sheet, the corrugated layer gives the mycelium space to grow into. Alternatively you can use corrugated sheets for all layers.
Spread the little pieces of mushroom evenly and fairly close together and cover with a sheet of cardboard.
Repeat until you have filled the container and the layers are filled with mushroom.
STEP 4: Store and Grow
Now you have the container ready, close the lid and store in a dark place at room temperature. Each day open the box to let some air out. Without any air exchange carbon dioxide levels build up and your mycelium will have stunted growth.
I put the container in a black bucket so it was in a dark place.
STEP 5: Watching It Grow
This is the exciting part. After a few days the mycelium will start to appear through the edges of the cardboard, this is why a clear box is the best as it allows you to see whats happening. It appears to seep through the cardboard, filling in all the gaps and holes.
Once the mycelium has reached a level you are happy with (I am still waiting for mine to completely surround the cardboard) you can heat the block to stop it growing any further. As my mycelium hasn't stopped growing I am yet to experiment with the heat process and the end product, when that happens I will update my instructable to explain my development. As I said in the introduction this is a work in progress project.
Thanks for reading.
54 Comments
Кэвэн 5 months ago
summonssunmind 1 year ago
Frah 1 year ago
lauragiragon31 2 years ago
newman9913 2 years ago
I say it's miraculous because nothing, save for the grapevine, was sterilized, the mushroom content consisted of one bag of dried mushrooms, I can not remember the type, and then cut and whole stems from button mushrooms.
My second attempt was completely sterilized and ended up moldy and full of worms.
I must have just found the goldilocks zone of mycelium and like I said, it's growing beautifully.
My question to you is, under what conditions can I cause the mycelium to fruit?
I have seen this and that about exposing it to small amounts of light, but there is too much conflicting information to deal with, as I am still new to this.
If you have reached the fruiting stage of your experiment, please tell me under what conditions did you get it to do so.
I know this was long winded, but your curiosity got my attention. newman9913@gmail.com
Thank you for your time
RedReign 2 years ago
LoveeHeavenly 2 years ago
faithmarytecla 3 years ago
Will they be exactly the same type of mushroom and edible ?
Thanks
TerêncioS 5 years ago
ashleyscarborough 5 years ago
solloek369fractallove 3 years ago
hanakarimoz 3 years ago
sattmghtay 3 years ago
Thank you very much for sharing this. Please answer me because it is important for me.
As this process can get Enoki mushroom for edible or can Enoki base grow like what did in this process. And also share if you know how to make Enoki seeds at home.
Best regard,
SMH
KayanS 4 years ago
mailtosudarshan001 4 years ago
ashleyscarborough 4 years ago
komanki1 4 years ago
could you send me how to collect this musroom mycelium and grow musroom.
JoeH233 5 years ago
MinM18 5 years ago
hi
how long days need mycelium growing in container box after that which thing(straw,etc) transfer ?.
