How-to Forge a Skull Crushing Robotic Arm to Do Your Dirty Work.
Intro: How-to Forge a Skull Crushing Robotic Arm to Do Your Dirty Work.
Also, if you could please vote for this instructalbe in the Microcontroller contest , the Toy contest , and the Make it Move contest it would be highly appreciated ;D
STEP 1: Design and Fab
For this project I used the lynxmotion arm as a large point of reference, but because the site does not actually give any CAD files or any dimensions of the older arm I was forced to make those decisions for myself. I used SolidWorks for the design of the whole arm assembly, this made everything go by so smooth since I could save the files as .STL or .Dxf and have a laser-cutter and FDM machine make the parts for me. Besides that the Items I used are:
1x 24x24 sheet of neon green lexan.
5x Hitec HS-422 servos
2x Hitec HS-645MG servos
1x box of 4-20 x 3/8 self tapping screws
1x box of 2-28 x 1/4 self tapping screws
some 8/32 x 1/4 socket cap screws
Check the next step to see what all the parts are used for...
STEP 2: What Goes Where?
The picture here shows where all the materials are used on the arm.
STEP 3: More on Fabrication
I never touched any tool on this project except a simple hand-drill, and yet the quality of this project is very high. My secret, I used a combination of laser-cutting, and 3D part printing. To print my 3D plastic parts I did work in SolidWorks creating the dimensions of the part which I saved in a .STL file and sent to an FDM machine which would drip plastic in a pattern in layers to construct a full plastic part. I mainly used this method to create supports between pieces of lexan that were not held by much other than servos. As far as using the laser cutter I used a similar process, but instead of saving the file in SolidWorks as a .STL, I saved it as a .Dxf which the laser-cutter could use as a path for cutting on flat sheets of material (i.e. lexan). One thing to highly note is that the base servos that lift the arm up, (the ones on the desk in the picture) will fight each other for position. In order to stop those servos from over heating and causing failure you have two options. The first option is to slot the holes in the lexan where they are mounted to the servo horn, this will allow for adjustment of the structure against the servo horn so that both servos will both be in the same position at the same time. Another method is to program both servos to go to 90 degrees, but take the horn off one of them. When both servos reach the correct position, screw the horn back on and it should be all set. Also note that I added a spring in the final design to assist the forearm in lifting.
STEP 4: All Your Base Are Belong to Us!
STEP 5: THE CLAW! and More...
STEP 6: Electronics
UPDATE (6/20/11): The arm has been mounted to the base, only things left to do are the electronics and programming. Also, the controller I'm deciding to use is an Arduino Duemilanove. It has just enough PWM outputs to control all of the arms movements. Hopefully in the next update I can upload a sketch of my code for others. I will add a video when the project is 100% completed.
Now that the arm is completed I have decided to make it into a modular arm for a larger robot, but that is for another day.
23 Comments
omodolor.stevedan 9 years ago
Can you tell me how you joined the two parts together at the other end of the servomotor
Fitty Charles 10 years ago
tinker234 12 years ago
deattila 10 years ago
but if you use springs so the arms weight is near nothing.
you would be able to make it out of alluminium with no problems
marvin T 11 years ago
if so please send to marvin@protospace.nl
berrybright17 10 years ago
alessandro290 11 years ago
dchakraborty 12 years ago
FlyingToaster 11 years ago
docdavies 11 years ago
mahsa arian 12 years ago
thx FlyingToaster
jcano yribarren 12 years ago
I want to make a robotic arm to play chess, but I don't know what to choose, stepper motor or servo. Stepper motors are more precise, but more expensive, heavier and i would need more mechanisms.
So my question is: do you think your robotic arm has precision enough to position pieces in a chess board?
Thanks and sorry for bad english.
FlyingToaster 12 years ago
jwkooi 12 years ago
But again: nice job
jwkooi
jwkooi 12 years ago
One servo will work, but you only have the strength of one.
Reposition the horn: I am curious if it works and keeps working over time.
Maybe it isn't that critical. Keep us posted wtih your experience.
jwkooi 12 years ago
sarveshk 12 years ago
See the link of the product http://www.futaba-rc.com/accessories/futm4150.html
