Introduction: Making a Digital Compass With Shake to Wake
This is an easy to use self calibrating digital compass that will automatically power down and wake when lifted. It incorporates a circular display with a spinning indicator for north and south.
Hardware
Required
- Seeed Studios Xiao rp2350 microcontroller
- Adafruit BNO055 orientation sensor
- GC9A01A Round display
- Case (files included)
Optional
- NPN transister
Software
- Arduino IDE
Step 1: 3D Modelling the Components
The first step towards making this compass real was rough modelling each of the components in Fusion 360 and designing a case to hold them all together.
Step 2: 3D Print the Case
Since I've already modelled the parts I've included a link for the case STL files, or just download right from instructables! https://www.printables.com/model/1541896-digital-compass-case
This just needs to be printed and you're good to go!
Step 3: Soldering the Components
Following the attached schematic attempt to compactly solder all the components together.
Step 4: Assemble
Fold up the electronic so they fit in the body, then simply press on the cover, making sure the LCD is aligned, you may need to use fine tweezers if it's slightly offset.
Step 5: Upload the Program
If your compass is slightly offset you can adjust that before uploading the program. Otherwise just download the attached firmware, compile, and flash!
Step 6: Done!
You should now have a working digital compass! move it in a figure eight to calibrate the sensor then give it a spin and watch the dial track north! Then watch as it automatically powers down after nine seconds then wakes up as you lift it!
