Introduction: Making a Gear
Check out more projects like this on Tinkercad.
Project Overview:
This project shows you basic tools in Tinkercad in order to make a gear.
Step 1: Add a Cylinder
Adding and resizing cylinder on the work plane.
Instructions
- Click and drag a cylinder onto the work plane.
- Change the cylinder dimensions to 35mm x 35mm x 4mm
- Stuck?
HINT:
Use the top white square to change the height
Step 2: Add a Box
Adding and resizing a box to the work plane.
Instructions
- Click and drag "box" onto the work plane
- Change the box dimensions to 45mm x 6mm x 4mm
- Stuck?
HINT:
Step 3: Center the Box in the Circle
Moving the box into the center of the circle
Instructions
- Left click and drag to select both the cylinder and the box.
- Select "Adjust" on top right drop down menu
- Select "Align" from drop down menu. Click on the two middle dots to center.
- Once aligned, click the "x" on the bottom of the screen to close the align function.
Step 4: Add More Boxes
Add more boxes for the teeth of the gear
Instructions
- Select the aligned box
- Copy this shape by typing "ctrl" + "C", or clicking "edit" + "copy"
- Paste this shape by typing "ctrl" + "V", or clicking "edit" + "paste"
- Using the curved arrow, rotate this box within the circle 45 degrees
- Use the align tool again to center the new box
- Copy, paste, rotate, and align two more boxes
Step 5: Add the Hole
Adding a hole to the center of the gear
Instructions
- Drag and drop another cylinder onto the work plane. Do not resize.
- Drag and select every shape and use the align tool to center.
- Select new cylinder, then click "hole" in top right of the screen.
Step 6: Finishing
Finish the gear!
Instructions
- Click and drag to select all shapes.
- Select "group" from top right menu
- You've done it! Enjoy your gear!
Congratulations, you have completed this project!
Check out other great projects on Tinkercad.
