Introduction: Making a Hand Drawn PCB.
For my latest electronics project I decided to make a resistor substitution box, instead of just using another perf-board I decided to make a pcb for it so I could document the process and make an instructable. I decided to do this because I have yet to see anyone do it on Instructables so I figured it would be a good thing to share. This process works well for simple circuits that do not have a lot of small parallel bus lines in them, I have done a few guitar stomp boxes this way as well.
Step 1: Materials
Materials to design and Draw the board:
-Paper and Pencil
-Ruler
-Sharpee
-Tape
-Scissors
-Tiny #65 twist bit (0.035" which is good for most electronic components)
-Dremal or pin vise to drill holes, the Dremal is the obvious winner here
-Copper clad PC board
Materials to etch the board:
-Ferric Chloride(FC), which is used to etch the board
CAUTION Ferric Chloride is a very corrosive liquid the vapor well cause steel to rust, therefor one must take all precautions nessessery in order to protect yourself as it well cause nasty burns and alike. So therefore you well also need
-Rubber Gloves
-Safety Glasses
-Paper towels to clean up spillage
-A well ventalated work area as the vapor is also quite nasty and not good to breath in.
Aside from all the safety stuff you need,
-A small resealable plastic container to put the FC into for etching and storage afterwards.
-A larger plastic container that the small one well go into for water and storage of materials afterwards.
-Warm water, goes in larger container to heat the FC.
Step 2: Designing the Circuit
Using paper and pencil design the layout of the circuit, it is easiest to do this as a top view of the board, it helps to also have all the different components on hand to help with spacing and placement. As a side note also make sure to design the layout so that it well fit on the board. If you already have a pre-designed layout you can skip this part.
Here is what my layout looks like for the resistor substitution box.
Step 3: Drilling the Board.
-Next you well want to make a copy of the design that is a reverse of the original, if you drew it in reverse or the one you have is already reversed just make a regular copy of it.
-Cut the copy of the layout out with scissors leaving some on either side so you can fold it around the PCB and tape it in place.
-Now using the tape, tape the design onto the copper side of the PCB. Mine is on the other side because I did not bother to make a reversed copy of it.
-With the #65 drill bit use the layout to drill a hole in the center of all the solder pads for the individual components. I like to set the board over something to catch the small fiberglass dust generated by the drilling, in this case a small glass dish.
Step 4: Drawing the Traces
-After you have drilled all the holes remove the copy of the design from the PCB and clean off all the dust.
-Using the Sharpie draw a solder pad around all the holes you drilled, helps to have a fresh pen with a sharp point for this, make sure the pen leaves a nice bold line otherwise it well not resist the FC as well.
-Now using the reversed copy of the layout as a reference draw in all of the traces with a Sharpie, if you make a mistake you can use alcahol on a bit of paper towel to erase the error.
-You can also use the Sharpie to add text to the board for connections or whatever.
-If you have not done so already, cut your board(s) out from the rest of the PCB stock.
Step 5: Etching
-Start off by finding a clean dry place where you can safely etch the circuit board, preferably outside.
-Put gloves and safety glasses on.
-Make sure you put your gloves and safety glasses on, Ferric Chloride is nasty stuff.
-Take your small container and pour about 1/4" to 1/2" of Ferric Chloride into it.
-Fill the larger container with warm water about 1" deep.
-Drop PCB into the Ferric Chloride, copper side up and place the small container into the water in the larger container.
-Gently rock the small container in the water so as to keep the FC moving which helps with the etching process.
-In about 5-7 minuites you should start to see the copper start to desolve away, notice the areas where the traces a drawn are uneffected.
-After about 10-12 miniutes the board should be completely etched, at which time you should emmediatly remove the PCB and drop it into the water in the larger container to rinse it and then dry it off on the paper towel.
-When you are done put the cover on the small container, you can use the Ferric Chloride over again a few times, and pour out the water in the larger container and rinse it out. You can use the larger container to store the small container and your extra Ferric Chloride that is still in the original bottle.
Step 6: Cleaning the PCB
-Using 0000 Steel wool clean the Sharpie off the the traces.
-Populate the board with components.
49 Comments
7 years ago
I do not live in the USA. Could someone please tell me what a "Sharpie" is ???
Thanks
Reply 7 years ago
Permanent marker
14 years ago on Introduction
Why we use Ferric Chloride? Is there any other way for Ecthing Process?
Reply 7 years ago
Muriatic Acid.
There is an Instructible for home-brew etch with an HCL (pool acid) recipe.
Reply 14 years ago on Introduction
Because I had it, simple as that, it is nasty stuff though. If you do some searching there is an instructable on making a homemade etching solution that is cheaper and I think I little safer, when my FeCl runs out I well be making some of that stuff.
13 years ago on Introduction
Check this out.
Draw your circuit directly on the copper board and drill the holes.
Paint the Circuit with NAIL POLISH.
Then start the Etching process.
The Nail polish will save your circuit from being etched.
The places not covered by the nail polish will be eached.
Job done.
Reply 13 years ago on Introduction
hmm maybe correction fluid? the type of pen that the shop here sells to mark is a "paint" pen.
I tried white out for artistic etching once. I found it rather hard to work with for even simple lines, and it had a tendency to lift in spots. Note that I was biting deeper (2-3X ?) than a PCB.
Yeah thats another way to do it, I think the Sharpee method is much easier to do and gives cleaner/finer lines.
Anyone ever try the type of pens that have metal in the ink and are prmanent like this one - Sanford Silver Coat and Gold Coat Markers Permanent, fadeproof, waterproof. Metallic ink works on most surfaces. Acid-free.
I would be leery. Some of those pens have mylar, or mineral flakes/dust, of unknown chemistry. Others have various metal powders/flakes, again of unknown chemistry, and all of them are paint rather than ink, with a wide variety of binders and fillers, again of unknown chemistry. I speak only from the expert knowledge of my ignorance, mind you. I wouldn't try it without some extra precautions. Who knows what you'll get?
I know there is a special pen that you can buy to repair pcb traces, it might be interesting to see what kind of conductivity that the stanford inks have and again it would be only for repairs as you couldn't solder too it.
I guess I was a little miss-leading in pointing out the metallic pens. I was just pointing out there might be better type ink pens that could be used then the permanent marker pens to hand draw circuits for later etching. Maybe they would less likely be undercut by the acid.
If they have metal in the ink, would'nt the etchant just eat the pen traces as well?
Think the Industrial Sharpie would work even better? And how about Cupric Chloride? I just mix Muriatic Acid and Hydrogen Peroxide I think its 2 parts H2O2 to 1 Muriatic Acid.
9 years ago on Introduction
when we use small marker pen to draw the lines, its really same as printed one!
This gives me a great idea! I'm working on a laser etching 2 axis machine. though it will be some time before I get a chance to build it, this instructable made me think of a very handy tool for PCB etching when you don't need to use CAD software...
If I can rig up simple x / y manual control of the laser using small stepper motors, like those in CD drive optics, I can take a thin piece of aluminum and laser cut footprints for different components, trace widths, IC holes and spacing, etc. the same general idea as using stencils to draw letters on paper. actually they should market something like this.
15 years ago on Introduction
i tried doing this before, it didn't work well to say the least the ferric went under the sharpie, and through the copper , leaving me with barely any traces all 3 of my homemade stompboxes didn't work, none of the traces stayed on, but i still tried anyways, so now i have $200 in wasted parts :\ not quite sure what i could do to salvage the stuff
get a desoldering iron. just curious... did you have black lines and did you let the ink completely dry for about an hour? I could see how the ferric chloride would just plow through traces made by a sharpie if they were put on there minutes before trying to etch it, for sure. and why didn't you take a voltage reader and measure resistance in ohms on a straight line / trace with the pin things an inch apart and see whether its conductive or not.
