Making a Viking Cloak-Pin
62,362
288
48
Introduction: Making a Viking Cloak-Pin
About: Retired museum curator.
Pennannular brooches are common to many cultures. This particular style has been found in Viking silver hoards. I've seen Roman brooches of bronze. Convenient modern materials are copper (#6 wire, the size fastened to the pipes in your basement) and brass (3/32" brazing rod). You'll also need a hammer, a smooth block of metal, jewelers' pliers (preferably round-tipped), a file, and a gas flame. I'll illustrate using a propane torch, but I've also used gas kitchen stoves.
Use the pin to fasten a cloak at your right shoulder. This leaves your sword-arm free, just in case. Or take a square of cloth, a pin, and you have a shawl for those cold days.
Step 1: The Body of the Brooch
Take a piece of #6 copper, 5-1/4" long. Polish it, then bend into a circle with the ends about 1/4" apart.
Step 2: Beginning to Form the Pin
Heat one end of the brazing rod with a stove burner or propane torch. Hot hammer about 3/4" length flat, using the metal block for an anvil. Thin it out to about 3/16". Neaten and smooth the end. Polish.
Step 3: Forming the Pin Loop
Heat the flattened end to soften it. Curl into a loop which is a snug, but not tight, fit over the #6 copper.
Step 4: Embellishing the Pin
Heat the brazing rod just where it passes over the copper ring. Leave the rod long enough that you can hold the cool end. Hot hammer the rod a bit wider, in a graceful leaflike shape. (This step is optional, but adds a bit of authenticity.)
Step 5: Finishing the Pin
Trim the brazing rod, and file to a neat point. Make it just a bit rounded, for safety's sake. Polish.
Step 6: Joining Body and Pin
With the pin on the copper ring, widen the ends of the copper ring by cold hammering until the pin can no longer escape from the brooch. The metalwork is now finished, though a bit of final polishing can help.
Step 7: Using the Brooch
To use the brooch to fasten two (or more) layers of fabric together:
1) Gather two layers of fabric. Push pin through.
2) Bring gap in ring down past pin.
3) Turn the ring underneath, so the pin is held solidly.
Step 8: Small Pins and More
Small pins can be used pretty much like safety pins. I have a friend who uses small pins to hold her flowing sleeves out of the way at table. And my Paddington Bear won a "Dress the Christmas Bear" contest wearing one to hold the cloak of his Druid costume on. (I also made him a small golden sickle.)
For a nice small pin, wind some of your 3/32" brass rod around a 5/8" rod to make a tight spiral. Cut off brooch bodies (like step 1, only smaller) so you have maybe a 3/16" open gap per body, then flatten then into a single plane. Use 1/16" brazing rod for the pins. Small ones can be worked cold.
I have also made these of sterling silver. It cold-works nicely when occasionally softened by heating in a flame then plunging into water. I've also done them in nickel silver, which behaves pretty much like brass.
The Instructables Book Contest
1 Person Made This Project!
  • Electronics Contest
    Electronics Contest
  • Stick It Challenge
    Stick It Challenge
  • Tinkercad to Fusion 360 Challenge
48 Comments
joerubberboots9
joerubberboots9
12 years ago on Step 8
you rock!
(patington rocks too.)i have a race of sock-creatures that i call moozies",and mine uses tow of your pins. one to hold his cloak of webkin skins,(he HATES webkins.) and one to hold his sword(letter opener) belt. do you think steel would work?
theguywitheyebrows
theguywitheyebrows
Reply 1 year ago
i forged a few out of regular nails, nail head clipped off, the shank used as the round, they ended up just over 1" (3.5mm) ish i left the pins long and unshaped as these were worked cold and thrown together as a test of my own skill and understanding. i also used a ribbed copper nail shank as a pin, smoothed some and rounded to a point. copper definitely looks better than nail steel but the scrolled flat wrap around the ring is definitely weaker. i have a 1/4" (6mm) brass rod that i would like to use to make the ring but i am afraid of flubbing the flats or bending somehow. brass is fickle and i an afraid of buggering it up lol.
Dr.Ellen
Dr.Ellen
Reply 12 years ago on Step 8
Dear Joe -
It depends on what you call "steel". Certainly you could make cloak pins out of wrought iron or mild steel - I have a lovely elaborate pin by Magic Badger Smithies, worked up as a dragon. With higher carbon content steel, you would have to start hot working your pins, and maybe hardening and tempering them as well. (You can check out a how-to on similar steel-work at Jewelers' tools.) Different detail, but the hardening and tempering should work about the same.
Ellen
Dr.Ellen
Dr.Ellen
5 years ago
It's called 6-gauge here, and used to make sure things are grounded so thoroughly they can take any electrical load they're likely to encounter. I guess I was writing for an American audience. It's a soft copper wire, about 4 mm in diameter. If the copper isn't soft enough, heat it red-hot and quench it in water. The same goes for silver or brass. You don't want it glowing brightly, but you should be able to see a bit of a glow.
The nice thing about the copper wire is that if it's soft, you don't need to heat it to work it. Silver and brass, you do.
Dr.Ellen
padawanspider
padawanspider
11 years ago on Introduction
Thank you for this instructable - I had seen a pin like this before and wondered how it fastened (I did not realize the barb could move around the loop). I think I may make a few of these!
Dr.Ellen
Dr.Ellen
Reply 11 years ago on Introduction
We have a bit of relativity going on here. Once the barb is put through the cloth, it stays still. The loop moves around under IT. ;^)
padawanspider
padawanspider
Point. What I meant to say is that neither the barb nor the loop are fixed to one another in such a way as to prevent rotational movement by one element while the other is held stationary. :D
(but what if I turned the fabric???)
red anger
red anger
12 years ago on Introduction
 neat instructable!
i will be making many.
av uh gud un.
Infinitevortex
Great illustrations and Instructible!
Did you scan the illustrations, or create them in software?
Dr.Ellen
Dr.Ellen
Reply 12 years ago on Introduction
I drew them in pencil on paper, then inked them. (It's been so long I can't remember if I used a pen or a brush.) Then I scanned them in.
yutzwagon
yutzwagon
I need to keep working on my viking costume for my brother's wedding, so this is great. Thanks!
De_frog
De_frog
Have made many of these penanular pins myself over the years and they're not as easy as it sounds. It's quite possible to "cold forge" them in steel if you don't mind hittin it hard, brass and bronze can be awkward if it work hardens... The first time I made one on a bellows forge I got carried away and melted my pin! :}
Dr.Ellen
Dr.Ellen
That's why I suggested copper for the circle, brass for the pin - the copper doesn't work-harden to an inconvenient degree and the work-hardening makes the brass stiffer. When you are learning the job, using the easiest and cheapest materials is wise. You can use trickier stuff later on. When I make one of these completely of brass, I hot-work the brass, using a propane torch. (It's harder to get carried away with a propane torch than a bellows forge.) If I make them of silver, I cold-work the silver, but anneal it whenever it starts to stiffen. I have one lovely iron brooch made by Magic Badger Smithies, but have never done steel or iron myself. Steel and iron are for utility in my world - tools, hinges, locks, stuff like that.
monster matt
monster matt
13 years ago on Introduction
very good Instructable but quick question what demisions did you use for your cloak having trouble getting a good cloak shape I have gone through about 8 or so yards of cloth. I would be very grateful.
Dr.Ellen
Dr.Ellen
Reply 13 years ago on Introduction
Wow, that's a rough question. I wrote an article about making cloaks, years ago. It's not machine-readable. I could xerox it for you and mail it - do you have a snailmail address you wouldn't mind putting on the Internet? ellen at washuu dot net
monster matt
monster matt
my email is at yahoo if thats makes any difference mwolfe29039@yahoo.com
Dr.Ellen
Dr.Ellen
Well, I had planned on a quick Xerox and a postal envelope, but that'd be a lot of data to send over the net. So I separated out the images and did OCR on the text, and a bit of edit and rewrite. You can find my article on making capes on my web site:
http://washuu.net/Cloak/Cloak-1.htm
Instructables is oriented towards pictures, with text. I'm more comfortable with text and illustrations. So it's easier for me to put old articles up on my own site.
halvis
halvis
I think it's awesome that you made this instructable! I would, however encourage makers to use other metals than copper, as it is fairly soft. Something harder might take longer to make, but will last forever, basically. Especially bronze ones. (I should know, I've found one!) The cloak-pin is actually called a ring needle and comes in two basic shapes; open and closed. The one you have drawn is the open, C-shaped one, and the one I found is the closed, O-shaped one. The O-shaped one, you have to pull the fabric through and then pin it. A bit more cumbersome, but cannot come undone. This is the same type as the one found in Newfoundland, and wich confirmed both Huseby (the dig site outside Larvik, Norway) and Newfoundland as Viking age. Both were made out of bronze. Bronze is probably the best material for ring needles, as it doesn't tarnish easily (though it will oxidize if it's left in the ground for 1000 years), but you can use iron too, but then the surface has to be treated so you don't get rust stains. The easiest way is probably melting some butter in a frying pan and actually frying the ring needle for a while. Wait until the butter gets good and brown, though. The soot helps. A couple of minutes should do, then pour the whoal thing down the drain, wait until cool and thoroughly dry off the fat with a paper towel. Don't wash it with soap or anything, you want that film of fat to stay on. Leave in a warm place for a while before using.
Dr.Ellen
Dr.Ellen
I love it! Fried cloak-pin! (Though I must say, I've tried that sort of thing with iron with less than complete success.)
