Introduction: Making a Wooden Drawer
Nowadays we take drawers very much for granted. They appear everywhere in the house; in the kitchen, the bedroom, the study and the workshop. They come in different sizes and designs. Some have mechanical slides and others run on wooden supports (called runners). But they all have one common feature: they are basically open-topped boxes that can be accessed separately and conveniently.
Step 1: Drawers in History
Towards the end of the 16th century, this weakness began to be addressed. It occurred to furniture designers that if you stack a set of smaller boxes inside a bigger box, and make sure that they are accessible from the front rather than the top, you can go straight to the items you want without unpacking everything.
To begin with, chests incorporated just a single drawer in the base, but by around 1650, drawers had become a common furniture feature and the chest of drawers, as we would recognise it today, had arrived.
Step 2: The Traditional Way
The drawer we're making here has a traditional dovetail construction and a solid timber bottom. The front is oak, to match the wardrobe it will be part of. The sides and back are ash, this gives a nice contrast to the oak and shows off the dovetails. The bottom is Cedar of Lebanon, which has an aromatic smell when newly worked. The handles are hand-turned knobs, made from American walnut, giving a nice warm contrast to the oak.
Step 3: Front First
Step 4: Equal Sides
Mark up the tails on the sides first. For the front dovetails, the depth of the tail needs to be marked up on the sides and the ends of the front board. Do this with a single setting of your marking or cutting gauge, photo 3. Reset the marking gauge to the thickness of the back and sides and mark up the rear faces of these components and the inside face of the front, to define the base of the joints. For a good balance, the dovetail positions can be marked up on the sides in pairs, photo 4. Mark up the dovetails from these positions with a sliding bevel. The tails are cut with a handsaw, photo 5, and chopped out with a chisel, a pretty quick job, photo 6.
Step 5: Tail Transfer
My approach has the sides about 2mm wider than the front, so there's a 1mm overlap at each edge. I've found that if you start with the boards exactly the same width as the front, any imprecision in marking or cutting can leave you with the boards misaligned, an undershoot at either the top or bottom and an overlap at the other, which has to be planed off. But you can't easily fix the undershoot. So I aim for a small overlap at both sides, which is then planed back. Not only does it give a neat job, but it's easy to ensure that the drawer sits squarely on its runners. This isn't what the textbooks say, but I find that it always works for me.
Step 6: Crafty Knobs
For a neat fit, you need to be sure that the dowel holes are drilled perpendicular to the face of the drawer front. This can be difficult to achieve drilling freehand, so I use a simple guide block drilled on my drill stand to ensure right angles. If you use a lip and spur bit, you can be sure you are drilling in the right place. Position the bit on the mark before sliding down the guide block and starting drilling. A piece of scrap clamped to the back ensures no tear out where the bit emerges.
Put a smear of glue around the inside of the hole and press the knob home. I drive a wedge into a slot cut in the dowels, to ensure a really tight fit that won't work loose over time. Make sure that the wedge is at right angles to the grain of the front to avoid the risk of splitting. When the glue is dry, cut off the excess dowel with a sharp chisel and sand it smooth.
Step 7: Chopping Times
You could speed it up by using a router to remove the bulk of the waste, but it's very easy to make a costly mistake, especially as you're cutting freehand. In this case, a bit of tough handwork was good therapy. Apply the same process to the dovetails on the rear panel. As they are through dovetails, and in an easier timber, this is a much quicker job to carry out.
Step 8: Testing the Fit
Step 9: A Drawer Is Born
With the drawer assembled, check the fit in its opening. If all has gone well it should fit first time, but don't be surprised of there is a bit of trimming needed to get an easy sliding fit.
For example, the opening might be slightly narrower at the back than at the front. Once it's sliding nicely, push it fully home and check that the front is flush with the face of the drawer opening. In my case, it stood a bit proud at the bottom left corner.
If this happens, mark the corner with a pencil where it stands proud, photo 13. Remove the drawer and plane back the drawer front to your pencil lines. If you've taken care that the front panel was flat, any adjustments you need to make will be only minor, as it was in my case.
Step 10: Drawer Details
However, the layout at the back needs a bit of thought, because it's central to the structure of the drawer. The base fi ts into grooves cut in the inside faces of the sides and the front. The dovetail design needs to accommodate this. The diagram (left) shows the side and rear aspects of the back dovetail joints. The bottom rear joint is a half dovetail, sitting immediately above the groove for the drawer bottom. The back of the drawer is not as deep as the sides, and butts against the upper surface of the drawer bottom.
If you plan this carefully, you can rout the grooves in the sides and front straight through, without stopping. This makes the job very easy and neat. The pictures show the groove geometry I used for this drawer and demonstrate the construction principles. The grooves in the side run through the bottom front dovetails and are hidden in the assembled drawer. On the drawer front, the matching groove runs into the dovetail cavity, also hidden. At the back of the sides, the groove lies directly below the bottom half dovetail.
Step 11: Back to Front
The drawer bottom needs to be screwed in position to the underside of the back panel through slots, to allow for this potential movement. Take care that the back is square and that it fits easily into the groove. If it doesn't, you'll run the risk of forcing the drawer out of square and jamming in the opening. If there's any tightness in the drawer at this stage, take out the bottom and do a little fine tuning.
That's it, ready for finishing and polishing. There's a lot of work in making a drawer. It needs careful measurement and planning, and a lot of handwork. But if you do it well, you know it's going to last for years, and your hand-cut dovetails will be proudly on show every time its opened.
