Step 1
62,448
6
21
Introduction: Step 1
Text
Step 1: Step 3
Be the First to Share
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    • Hand Tools Only Challenge
    21 Discussions
    6
    andreiastark
    andreiastark
    Question 1 year ago
    This project is no longer available? :(
    bekathwia
    bekathwia
    4 years ago
    Beautiful, thanks for sharing!
    fshaik
    fshaik
    6 years ago on Introduction
    Can you please provide a link from where you bought the "Lighting white" acrylic with that percentage transmissive. And I believe this is the top layer with which bezels(triangles have been made). ??
    MeiH1
    MeiH1
    Reply 4 years ago
    I just used white acrylic paint, found at an arts/crafts supply store. Worked great!
    pachytrance
    pachytrance
    4 years ago
    Thanks for share. Awesome!!
    fshaik
    fshaik
    5 years ago on Step 1
    Hi Can you tell me where to buy titanium dioxide, I think thats a very important component in this project, as the regular led wont diffuse and you will still have hot spots.
    shauncorr
    shauncorr
    This is awesome. I'd like to make something similar, perhaps with a different shape or size. Can you give me an idea for your overall dimensions of the triangle?
    Also, I've been looking a neopixels and have had trouble finding the strip you used. Did you buy a weatherproof strip and remove the coating?
    Thanks for this! I hope to make one and then use it for projects to help me learn to program.
    alcurb
    alcurb
    Beautiful piece. I'm very impressed with the quality of your work.
    I wish I had the laser-cutter resources to use your techniques to build my own version. I do have a laser-cutter available, but I can't afford to join the TechShop in San Francisco. I'll have to find other techniques. Maybe I can user foam-core, but foam-core is not durable, unfortunately.
    gen81465
    gen81465
    Brilliant! Illuminating! (no puns intended) :)
    Here's an idea to to extend this. If each triangle were touch-sensitive, wouldn't it be interesting to use it as a sort of futuristic-looking door lock (access keypad). You could program it to unlock a door, only after a specific geometric pattern had been entered.
    scanlime
    scanlime
    Reply 6 years ago on Introduction
    Yeah! I've wanted to make it interactive with a capacitive proximity sensor circuit using the bolts as sensing antennas :)
    nqtronix
    nqtronix
    This is incredible impressive! Things like this make me wish I'd have a laser cutter.
    In the video it ssems like all patterns are generated on a computer, what program did you use for that and how were you able to send all that data to the LEDs?
    scanlime
    scanlime
    I used the Fadecandy LED controller, an open source hardware project I started last fall. The Fadecandy boards are available from Adafruit now: https://www.adafruit.com/products/1689
