Making a Simple Laminate Longbow
Intro: Making a Simple Laminate Longbow
This is a short guide on how to make a VERY simple laminate longbow. If at the end of this tutorial, you have any questions that are not answered, or you would like more detailed instructions on how to make a longbow, check out www.makingtraditionalbows.com
STEP 1:
Step 1
Cut the laminates using a circular saw or a band saw. The dimensions of the belly laminate should be about 75" by 1 1/2" by 1", and the dimensions of the back laminate 75" by 1 1/2" by 3/16". The grain of the back laminate must run straight down the length of the board and be uncut.
When shooting a bow the belly side is towards you and the back is facing away.
Optional belly woods: Yew, osage, lemonwood, ipe, oak and more.
Woods for backing: Hickory, ash and more.
STEP 2:
Step 2
Glue the laminates together using the strongest wood glue you can find, then use clamps and alike, to clamp the laminates together. Let the glue dry.
Glue recommendations: urac 185, smooth-on, UHU plus endfest 300 and Casco actually makes a two component boat glue that also works. Important! Always mix the glue well.
STEP 3:
Step 3
When the glue is dry, mark out the bow. Draw a straight line down the centre of the bow stave, and with reference to the line mark out the width of the bow.
Width: 1 3/16" at the centre and then let it taper evenly down to 1/2" at the tips on both sides.
Thickness: 1" at the centre and then it taper it down to 1/2" at the tips (Important! Only taper the belly side).
Step 3 1/2
Cut the belly tapers and then cut the back tapers (In other words, simply cut along the lines you just drew).
STEP 4:
Step 5
Shape the belly of the bow like it is shown in the photo and carefully take the edges of the back laminate. A rasp works fine for this job.
STEP 5:
Step 6
Make some temporary nock grooves using a 5/32" round file.
Fit a temporary bow string and slowly start bending your bow. If and when the bow bends nicely carefully draw it a little further, if any stiff areas present themselves, remove a little wood from these areas and NEVER from the weak areas. Continue like this until the bow bends nice and evenly throughout the entire length of the bow. If the bow is too strong you need to remove wood from the entire length of the bow, but be careful you do not remove too much. Important! When doing this work only remove wood from the belly side of the bow, not the back.
STEP 6:
Step 7
Sand the bow and apply the final touches to the nocks.
Last apply a varnish and fit a bow string and you are ready to start shooting.
82 Comments
FrancisAho 1 year ago
Thank you.
cyclerambler 2 years ago
thanks
highjacked 12 years ago
Lord Jon Bigglesworth 12 years ago
In any case, there is no measure of how much power the bow has per say, unless you know exactly how far back you draw it every time, and you know the equations based on your bow, the type of wood, the string, your draw length, etc.
TheOriginalNerd 4 years ago
cblackwell 12 years ago
The hold position seems to come from a military background where archers worked in groups rather than a hunting style where they worked alone. For most native traditions the range was much closer than modern hunters would believe. 3 to 10 feet being the range for a honorable kill of the animal. "the arrow would enter the animal before the fletching/feathers passed the hand." It takes good stalking or hiding/camouflage/scent masking skills compared to a tree stand shot at 50 feet. A different skill set for a different time and tradition.
RichardP28 8 years ago
DaiVrath 12 years ago
Other than that everything you said was right on.
I've been a professional longbow archer for over 19 years and some my friends/co-archers have been at it a lot longer than I. Question: What is the draw strength(weight) of the bow? Answer: It depends on several factors, Type, thickness, width, length and shape of the wood/bow, temperature, the twist in the bow string, age of the wood and age of the bow, the persons draw length and more. Draw length is different for every person, but the average adult's draw length IS 28" and while that average is very common, it is obviously not the same for everyone and as ChrisMBows points out the distance a person should be drawing the bow back to these days is the corner of their mouth or check, but it is more important to draw consistently to the same spot than how far back you draw and people never would have back past their ear or there would have been a lot of 1 eared people back then.
One more thing about weight; the archers of the Middle Ages could draw bows of 150 - 180 lbs. Some of my co-archers use 90# to 120# bows.
Otzi, the "Ice Man" had a long bow with him when he was found in the Alps. He lived some 5300 years ago. So the longbow has been around many hundreds of years. It was eventually replaced by guns/gunpowder, because, as 1 comment pointed out correctly, it was easier/quicker to teach someone to use a gun (or cross-bow) than a longbow.
SavannaK4 7 years ago
ChrisMBows 12 years ago
As mentioned, the draw weight also depends on your draw length (the distance from the back of the bow to the string when you draw the string back to shoot the arrow). On average when target shooting, this distance is 28" and most people use the corner of the mouth or the cheekbone as an anchor point.
scorpman 12 years ago
Mrjamfunkalot 12 years ago
AngusL7 4 years ago
Ghost Wolf1 7 years ago
What is the best woods to use
KingJingaling 6 years ago
i've heard that yew is the most common to use, due to it being strong but flexible. but other types work just fine
AngusL7 4 years ago
Zach S.B 7 years ago
Where is a good place to buy bow strings long enough for a 76" bow (i.e. 73")? Most every place I've looked has only stocked up to 68".
