Introduction: Making the Drill Press. Is It Worth It?! [Build + Tests]
In this instructable / video I will be making my designed homemade drill press with the model 775 motor. It's speed will be controlled with the 10A PWM speed controller. Also I will provide key tests for you to decide if it is worth time and effort to make a tool like this.
FINAL DIMENSIONS - http://bit.ly/DIY_Drill_Press_Dimensions
Provided Amazon links are affiliates
Main Tools You'll Need:
- Drill https://amzn.to/2U5QQmL
- Jigsaw https://amzn.to/2rg4uXx
- Clamps https://amzn.to/2E8EBkQ
- Speed square https://amzn.to/2Ee6lDh
- Soldering kit: https://amzn.to/2Q613Bf
Main Materials You'll Need:
- Plywood 12mm (1/2) thickness https://amzn.to/2YY8hHG
- Plywood 18mm (3/4) thickness for the base https://amzn.to/2W4guYM
- Drawer sliders 30cm (12inch) https://amzn.to/2YV7Cqg
- Tension springs https://amzn.to/2KgVeNt
- Model 775 DC Motor https://amzn.to/2Inbha3 or model 895 DC Motor https://amzn.to/2Z2LOJI (needs 12-24V 10A PSU)
- Chuck 0.6-6mm https://amzn.to/2QCkmzk
- Bracket for 775 motor https://amzn.to/2ELXf0n or for 895 motor https://amzn.to/2ELXf0n
- 10A speed controller for 775 motor https://amzn.to/2QEokaO
- 20A speed controller for 895 motor https://amzn.to/2JQQRsQ
- Closed 24V 5A power supply for 775 motor https://amzn.to/2WhtNtS
- Open 24V 10A power supply for 895 motor https://amzn.to/2I4eQkY
Other Things You'll Need:
- Screws, bolts, washers, self-locking nuts, wood glue, wires.
Video Shot with:
- Canon SL2/200D https://amzn.to/2H254k6
Used Lenses:
- 24mm f/2.8 STM https://amzn.to/2vy1HuJ
- 50mm f/1.8 STM https://amzn.to/2DEMegL
You can follow me:
- YouTube: https://www.youtube.com/diyperspective
- Instagram: https://www.instagram.com/diyperspective
- Twitter: https://twitter.com/diyperspective
- Facebook: https://www.facebook.com/diyperspective
Step 1: Preview
Some preview shots of the drill press.
Like what I do? Consider becoming a PATRON! This is a great way to support my work and get extra benefits! https://www.patreon.com/DIYPerspective
Step 2: Main Parts
I always design my projects first as 3D model. This way it is much easier to achieve the desired project compared to making it on the go. First I cut all main parts. Here are all dimensions if you want - http://bit.ly/DIY_Drill_Press_Dimensions
Step 3: Sliders
To move drill up and down, I used a pair of heavy duty drawer sliders. They are perfect choice for this action.
My moving drill part is shorter than the length of the sliders, so I just cut the ends to get a better look by not sticking out.
Step 4: Making the Towers
First I glued few pieces to get bigger surface area that will be connected to the base.
To easily secure the slider to the inside sliding part, first I glued both parts with double side tape and then secured it with pan head screws. With same method, I secured other side of the slider to the previously glued part.
Then both made "towers" can be glued to the base.
Step 5: Finishing Towers
As gluing is to just easily secure both parts at correct angle, later I additionally secured those "towers" with big long screws. On the top of them I glued small piece which will give rigidity, will act as a stop-block for a max height and will hold the tension spring. So it also must be secured with two screws.
Step 6: Motor Sliding Part
I stacked 4 plywood pieces on top of the sliding base part. When glue completely dried up, I clamped that part to the inside sliding parts and secured them with four screws.
Step 7: Mounting the Motor
For this project I used model 775 motor, L shape holder and drill chuck with adapter to the motor. To get perfect 90-degree angle it is just a trial and error alignment process.
Step 8: Tention Spring
At this point motor just stays down on the base. Simplest way to lift it up is to use tension springs. It is important to secure the spring with bolts, washers and self locking nuts and not with wood screws.
Step 9: Making the Lever
To lower the drill I am making a basic lever system.
Step 10: Making the Lever
All pieces can be secured not too tightly with M6 bolts, washers and self locking nuts.
Step 11: Finishing the Lever
To get the best possible drilling results and satisfaction when using it, lever should be from both sides.
With levers in place, I first glued small piece that connects them and then additionally secured with screws.
Step 12: Powering the Motor
To control motor's speed I used a common 10 PWM speed controller.
To power the motor, I used open style 36V 5A power supply.
Step 13: Power Supply
From what I tested, with a max 6mm HSS wood dill bit, you can power this motor easily with 24V 5A power supply. 36V is kinda overkill, but I just had that PSU lying around, so I used it. But don't use 12V power supply, with it motor just stalls when drilling harder wood like plywood.
Step 14: Finishing Power Delivery
36V from the power supply wires goes to the speed controller's connections where POWER + and - are written.
Wires from the motor goes to the speed controller's connections where MOTOR + and - are written, it is a very basic circuit.
Step 15: Drill Press Stand
To slightly lift up the drill, that it wouldn't drill into things that it is on, I made very basic stand. It screws to the main base. And this is pretty much it.
Step 16: TEST
Here are some test results. All tests you can see in my provided video in the beginning.
This drill press is inexpensive to make and drills really clean perpendicular max 6mm holes. For bigger holes this model 775 motor just doesn't have enough torque. You can apply more voltage to get higher torque, but then it spins way too fast, which is a safety concern.
You can use something like the model 895 motor (24V 6000RPM, low speed version), which has almost twice the
torque, but it won’t be any close what even a cheapest drill presses can do.
Step 17: END
In conclusion, if you need a tool for small perpendicular holes in wooden materials, DIY drill press like this, works pretty well. It makes fast, clean holes and doesn’t cost much. On the other hand, if you expecting for a DIY drill press like this, to make bigger holes, I am sorry, but it isn’t the tool for the job. You are better with buying even a cheapest drill press from a store.
I hope this instructable / video was useful and informative.
If you liked it, you can support me by liking this Instructable / YouTube video and subscribing for more future content. Feel free to leave any questions about this build. Thank you, for reading / watching! Till next time! :)
You can follow me:
You can support my work:
17 Comments
3 months ago
Do you have this in solidworks please?
4 months ago
If you think this drill press has limited utility, you should check out the press made with laser cut wood being offered at aliexpress. I ordered one just to see how ridiculous it is and I also enjoy putting that stuff together. Maybe I can improve on it. Also, I thought I might be able to drill tiny holes (1 to 4 mm) in PCB board and plastic gears and such. People say it isn't steady. I've been considering getting one of those laser cutting machines just so I could make boxes and stuff, even though I have no real use for them.
Question 2 years ago
Will this be able to drill through 0.5cm thick annealed steel? (soft steel that's not yet heat treated?) thanks
3 years ago
Seems like a good application for a dedicated tool, like a plug cutter.
Tip 3 years ago on Step 2
Nice idea to go for. However, I am thinking about a combination of this model and a drill press for pcb's: a longer arm (or: more then 4 plywood pcs on top of the sliding base part glued) and a shorter swing. Nice added value I think.
Reply 3 years ago
Thanks, yes, feel free to modify for your needs :)
Tip 3 years ago
You should try one of those drill guide...775 motor is high speed low torque low watts (120-240) while normal drills are 500 watts +.
it'll tend to not drill into hard materials and will wear off your drill bits faster. Try getting hold of motors with speed reduction gearbox.
Reply 3 years ago
Woops...turns out, dremel 395 is indeed 120w
Reply 3 years ago
This build is orientated to get good drilling results at low
price. For woodworking, I always prefer higher RPM, it gives super clean hole
edges. Also, 775 motor with load spins noticeably slower. Don't overheat drill
bits and they will last long.
Reduction gearbox is a good idea, but those cost at least 2x the motor price.
Then the total price gets quite high and I would just invest more to get a
That's my thinking.
Thanks for the feedback! :)
Reply 3 years ago
Surprisingly, Tamiya makes reduction gearboxes with nylon gears that cost about $15-20. And it just mounts right on the motor.
Reply 3 years ago
Thanks for the info!
Reply 3 years ago
Or save yourself a fortune a total waste of time and won't fall apart in a week and buy one from Harbor Freight for $67.00. https://www.harborfreight.com/8-in-5-speed-bench-drill-press-60238.html
Reply 3 years ago
I bet there is a bigger probability that this 67$ will fall apart in a week than a DIY one, ha ha! Also it is only 300W one. I own several very cheap tools, and they are just pain to use. I would say, it is a waste of money to buy the cheapest tools. If you are buying a tool just save some money and buy at least mid range tool..
I am not saying the DIY tool is the way to go, but it is hugely rewarding when you make it, it works really well ant it is very satisfying to use (perspective of the DIY enthusiast). It's the experiance! Cheers!
3 years ago
For the cost, I'd say, it isn't worth making. For the creativity and skill that you put into this project. It is priceless. Thank you for sharing with Instructable.
Reply 3 years ago
If you want to make it and you need to buy all the parts then yes, definitely not worth it.
This tool reflects more my specific needs. I don't have much space and permanent location for it, so the ability to easily move it from one place to another is really nice.
For the process of making it, yes it is priceless. It gives so much joy when your designed and created tool works like intended. To be honest, it is more satisfying to use than my $300+ cordless drill, and that drill is really really nice to use. :)
Question 3 years ago
"A drill press is typically measured by its "swing", calculated as twice the distance from the center of the chuck to the closest edge of the column. Thus, a tool with 4" between chuck center and column edge is described as an 8" drill press."wikipedia.org/wiki/Drill#Drill_press
What is the swing of your drill press?
Answer 3 years ago
It's around 6.7 inches.
