Man Make Spoon
Intro: Man Make Spoon
Materials: Block of wood
Hand chisel
Bansaw
Vice grips
Two handed shaver
Confidence!
Hand chisel
Bansaw
Vice grips
Two handed shaver
Confidence!
STEP 1:
First choose your type of wood. If you’re a beginner go with a cheaper softer wood like pine. If you want to make a really nice spoon choose a good hard wood like maple.
STEP 2:
Second choose your type of spoon, There are two options either just a stirring spoon or a scooping spoon like a ladle.
STEP 3:
Then cut out an 8 inch piece of wood.
STEP 4:
Next trace an outline of the spoon you want onto the block of wood.
STEP 5:
Then use the bansaw to cut out the head of the spoon.
STEP 6:
Vice grips are necessary to hold down the wood.
STEP 7:
Use a small hand chisel to start scraping out the head
STEP 8:
When starting with the chisel make one deep groove to mark how deep you will chisel the rest.
Make sure you go with the grain as to not wreck the texture of the spoon.
Also make sure you’re not going to close to the edge or you will blow out the side.
STEP 9:
When you are done making the spoon head return to the bansaw and cut out the rest which should be the handle.
STEP 10:
Then you will use the two handed shaver to start thinning the handle to a good round shape
STEP 11:
Once your done shaving the handle use fine grit sand paper and sand the whole thing down to your liking, then your done!
6 Comments
techshop1 12 years ago
Very well done!
I am in the shed! 12 years ago
skimmo 12 years ago
Wi11 12 years ago
weldor 12 years ago
One time at Scout camp I needed a spoon and fork (I had forgotten to bring them) so I picked up some used boards similar to what you are using and carved them out with an old pocket knife. I am glad to see a young person such as yourself learning to do it in the shop so that you learn to make a good quality piece. Mine are rough at best.
Keep up the good work!
zomfibame 12 years ago
