Introduction: Man's Hand Goblet OR Vase
In this instructable I will show you how to make a Vase, or Goblet from fire wood.
Step 1: Things Needed:
Lathe
Bowl Gouge
Sander
Sandpaper
Screwdriver and screws
Wood
Polyurethane (optional)
Step 2: The Face Plate
Screw the Face Plate on the wood. Make it as centered as you can. Then attach it to the lathe.
Step 3: Shaping the Goblet
Start rounding the side of the goblet.
(Look at the GIF)
every little bit stop the lathe and look at the wood.
Step 4: Making a Groove in the Middle
After you are done rounding the side, start making a groove in the middle.
After you made a groove in the middle, start working from the middle to the top with the bowl gouge.
(Look at the GIF)
Step 5: Shaping the Bottom
Then take a pen and mark about one inch from the face plate, so later when you are cutting the wood off the faceplate you don't hit the screws. Then place the gouge in the middle, and work your way to the mark you made earlier.
(Look at the GIF)
Step 6: Sanding the Side
Sand the side.
My favorite way to sand a bowl or goblet is to use an electric sander, sanding with the grain of the wood.
Tip: Don't have the lathe running at the same time if you are using the electric sander!!!!
Step 7: Shaping the Inside
Move the tailstock, then position the tool rest so it is right in front of the goblet.
Place the bowl gouge a couple of mm away from the side and start moving the gouge from the side to the middle.
(Look at the GIFS)
Step 8: Sanding the Inside
Turn the lathe on, then start sanding with 100-350 grit sand paper.
Step 9: Cutting Off the Bowl
Take the parting tool and start parting off the bowl at the one inch mark that you put on earlier.
(Look at the GIF)
Step 10: DONE!
You are done! If you want to drink from it put some polyurethane on and in it, or you could make it into a vase, it's your choice. Mine was too big, it wouldn't fit anyone's hand so I went with the vase idea.
Thanks for reading
Please vote, like, and subscribe.
And if you make it please share a pic.
Trash to Treasure
2 Comments
4 years ago
Did I already comment that i am supa jealous of your lathe? Cause I is.......
Nice vase thingamajiggery. Good work. I am not refined enough to make something as classy as a vase :)
Reply 4 years ago
Thanks! I was very blessed with a lathe.
