Marble and Metal Pendant Necklace (3 Versions)
Intro: Marble and Metal Pendant Necklace (3 Versions)
First - let’s say I have collecting issues with marbles. I have bags and bags of marbles – buckets and buckets of marbles. I have marbles everywhere, I love marbles – there, I have said it.
I wanted to share some of my marble and metal pendants; three versions
1. The bottle cap style
2. The sun burst style
3. The tab style (I wish I had a fancier name for this one)
I will be showing an instructables on cut marbles (not completely round) to make 3 pieces of jewelry.
Remember to practice and use shop safety – use protective eyeglasses, dust masks and gloves. Know how to safely use the equipment before you start. No loose clothing, hair or objects around moving items. Remove your rings.
STEP 1: Items Used
- Marbles – American made Glass marbles – called shooters – approximately 9/16 inches in diameter. Fireballs, blue mist, cats eyes – they are all good
- Thin Brass Stock
- Diamond wheel cutter – wet saw with 12 inch blade
- Disc punch
- Doming block with dome punch
- Hammer
- Tin snips – light duty
- File
- Sandpaper – aka emery – I like wet versions – grits on hand- 100 220 400 600
- 8mm ring and 5mm ring
- Small pick – used on the sunburst version
- Necklace material – can be chain, leather, string
STEP 2: Get Started Cut the Marbles
I started by selecting my marbles; I tried to get a variety to pick from and cut extra (just in case). My goal was to pick the best color and pattern to face forward. I used a diamond wet saw to cut the marbles slightly off center, leaving the larger side to keep for mounting.
STEP 3: Metal Cutting
I like using thin brass to work with. It cuts with light duty tinsnips and can be worked (folded, punched, etc…).
Using a disc cutter, I punched out 1 inch diameter brass discs. Again cut extra. I was fortune with having access to a nice disc cutter.
The disc cutter leaves a little bur, so I used a general purpose file to smooth.
I followed up with emery paper - 400 grit
Note: Most of the time I make a card stock pattern with a compass, cut it out – and then trace the pattern onto my brass stock. I would cut the disc out with my snips.
STEP 4: Forming Metal - Three Versions or Styles
Forming metal - Three versions
3. The tab style
STEP 5: Version 1. the Bottle Cap Style
Using the 1 inch disc; I started by using a simple punch to put a hole in the edge for the 8 mm ring.
I used a doming block to start collapsing the brass disc
Then I put the doomed disc into an undersized hole in the disc cutter. Using an even smaller disc cutter (the size of the marble) pushed the disc down in the hole.
I placed an orange cut marble into the center.
Using my pliers, I closed up the folds of the brass – to secure the marble inside.
Added the 8mm ring and necklace material
STEP 6: Version 2. the Sun Burst Style
Using the 1 inch disc.
I placed the marble in the center of the disc and traced around it.
Using my tin snips I cut diamond patterns (to make the bursts) around the disc (I really just used my eye to create equal rays).
Using my pliers I bent the rays at approximately 98 degrees upward towards and towards the center. At the tips of the rays, I did another slight bend inward.
Placing of the white & blue marble requires a roll in process. Tip the marble slightly and push into the center. Now with a small pick, gently pull the rays out one by one. As you are pulling the rays out, push the marble in. It is kind of like changing a tire.
Using my pliers, I closed the bursts or rays of the brass – to secure the marble inside.
I left one sun burst ray to be completely folded over to hold the 8mm ring
The necklace material was attached through the ring.
STEP 7: Version 3. the Tab Style
Using my tin snips I cut straight patterns (to make the tabs) around the disc (I really just used my eye to create equal tabs).
Using my pliers I bent every other tab at approximately 98 degrees upward towards and towards the center. At the tips of the tabs, I did another slight bend inward. The balance (the other every other tabs), I bent flat against the back.
Placing of the red marble requires a roll in process. Tip the marble slightly and push into the center. Now with a small pick, gently pull the rays out one by one. As you are pulling the rays out, push the marble in. It is kind of like changing a tire.
Using my pliers, I closed the tabs of the brass – to secure the marble inside.
I added the 8mm ring
STEP 8: Some More Photos
With skin reactions to different elements, I like to coat my wearable jewelry with a protective coating.
Thank you for viewing my Instructables
10 Comments
hunter999 10 years ago
Really awesome idea, I like the bottle cap one :-) Thanks for sharing.
Fikjast Scott 10 years ago
valkgurl 10 years ago
Happy to know that without being a marble "collector" there are others who share Marble Addiction Syndrom.
Hi my name is ----and I have a problem.
Worse I passed it on to my grand daughter.
I must ask--WHERE are you finding such NICE marbles??? I have many many nice OLD marbles inc gem stones; real agates and clay but new marbles mostly look bland and pale---YOUR marbles however look smashing! Please share!!!!!
These designs are great---the "Tab Style" one could also be called a "Prong Set" style----
Well I am on the lookout for marbles all the time; the ones shown were found in a museum shop. Last year I was in Branson Missouri and they had a store called the 5 and 10. They had a great selection.
I see on the internet you can get some from marble king (like the package shown) http://www.marblekingusa.com/
I must have been a pretty good marble player when I was little. I had a few jars full. Side story, I was hitting the marbles out into the field with my baseball bat and my mother took all of them away from me. She said I would thank her one day. She put them on the kitchen window sill. Well I was much older and still collecting and she gave them back to me. Wow - mom was great.
Well I stopped counting mine after 60,000 marbles; but there is a lady I believe in Missouri that has dedicated her whole house to marbles. I think they call her the Marble Queen.
I put out a tray full of free marbles in front of my Rock display case every year at our rock club show, they go quick.
Back to finding nice ones, luck, luck, luck. I stopped at garage sale down the street from me and said I liked marbles. The man invented a game using marbles – he just gave me boxes and boxes of marbles.
I have a small collection of handmade marbles. I find these sometimes at craft shows. A foam gun case works great to store them.
Well, almost done. I have been working on building a machine to make stone marbles. Rock people called them sphere machines. I made one machine but it scared me to use it. I hope to get a new one done. I have boxes of raw agates waiting.
If you are ever in Michigan just let me know, I will trade you. Actually I would just give you some.
cheerfully scott
Aeon Junophor 10 years ago
Really great idea!!
Love it
Youras Aeon Junophor
I use to worry about every chip in my marbles, but seeing people wear them calms me down.
Tarun Upadhyaya 10 years ago
Penolopy Bulnick 10 years ago
So cool! They make me think of Pokemon Badges for some reason :P
You made my day
Thanks
I had to look up the word notion to make sure I was using it correctly. Wow what a word.
A mental image or representation; an idea or conception. A fanciful impulse; a whim.
A general understanding; vague or imperfect conception or idea of something: a notion of how something should be done
An idea or opinion. : An idea about doing something: a sudden wish or desire
