Marine Fuel Filter Changing Is Easy As Pie You Need to Do Your Own Maintenance So You Know Your Boa
Intro: Marine Fuel Filter Changing Is Easy As Pie You Need to Do Your Own Maintenance So You Know Your Boa
Doing your own Maintenance helps you know your boat better and this will pay off by saving you money now and if you have trouble on the water you will know much more than the average boater does!
STEP 1: Remove Old Filter
Please watch the video on You Tube it helps support the Instructables we do.
Do not spill the fuel in filter
Video show the process on 3 filters
STEP 2: Clean Mounting Surface
The Mounting surface needs to be clean to avoid leaks
STEP 3: Oil on Filter
Put a thin coat of oil on the rubber "O" Ring
STEP 4: Install and Tighten
Tighten hand tight then snug lightly with wrench, do not over tight.
Start engines and look for leaks
Thank you for watching,
Please follow us on Instructables and Subsrcibe to the You Tube Channel it helps support the work we do.
