Marshmallows, Yummy!
Intro: Marshmallows, Yummy!
Marshmallows are so yummy. We look at their jet-puffed perfectness and float away on visions of marshmallow topped yams, hot chocolate, and moon pies.
I first got the idea in my head to make marshmallows when a friend of mine reported that her “cookie a day” update was for graham cracker cookies with a from-scratch marshmallow filling. How fabulous! Marshmallows from scratch? I went straight home and pulled up marthastewart.com and pulled up the marshmallow recipe. Then I Googled and compared Martha’s to a recipe on Cooks.com and then to a recipe blogged by Smitten Kitchen. Ultimately I found Martha’s recipe to be the most friendly to the lay baker, and was pleased with the ingredients she listed, minus the vanilla bean. Smitten Kitchen’s recipe called for egg whites and as we have an egg allergy in our house we try to avoid using eggs in too pure a form.
Here is my recipe as it ultimately was used:
3/4 ounce gelatin
1/2 cup cold water plus an additional 1/4 cup water
2 cups granulated sugar
2/3 cup light corn syrup (which I used simply because I had some on hand, you can make them without as well)
pinch of salt
teaspoon of vanilla
vegetable oil (for greasing)
mixer
mixing bowl
non-stick saucepan
3/4 ounce gelatin
pinch of salt
teaspoon of vanilla
mixer
mixing bowl
non-stick saucepan
STEP 1:
Oiling the pan is an excellent job for little hands. They have a great time scrabbling around and being silly with the vegetable oil. But double check to be sure that they covered the entire surface! Even in their zeal they can miss spots and you don’t want your marshmallow to stick to anything! Its a bond that almost can’t be broken.
STEP 2:
Once your pan is oiled lightly, lightly coat the oiled pan with powdered sugar (like flouring a bread pan). Another job kids will love to take charge of! I gave one of them a quarter cup measuring scoop, they scooped up the sugar and dumped it in the pan. Then the other one got to do the shaking. By the way, don’t wear black to make marshmallows. White powder and white threads of sticky goo show up in the darnedest places!
STEP 3:
Next, let the kids take turns tearing open the gelatin packs and pouring them into the mixing bowl. This is a great time to start making observations about your materials. Gelatin is a gritty powder, until you get to the next step and pour the half cup of cold water over the pile of gelatin. Let them swirl the bowl to make the solution and set aside.
STEP 4:
To your saucepan ad the granulated sugar, corn syrup, and 1/4 cup water. We added the sugar first then observed the consistency and texture of the sugar versus the corn syrup, and of course a taste test was called for! It was further interesting to see that the corn syrup did not absorb readily into the sugar but coated it instead.
Once your ingredients have been added to the saucepan its time to heat it. Bring the mixture to a boil and let it boil hard for one minute.
While the sugar mixture is heating, visit the mixing bowl of gelatin and water. The kids will be shocked to discover its become a funny, spongy lump! Let them push on it and feel it and discuss.
STEP 5:
After the sugar mixture has boiled for one minute pour it into the mixing bowl and commence mixing. This will take between ten and twelve minutes. Do not be afraid if using a hand mixer! This is a fun process and the minutes fly by. You can let it cool for a few minutes before mixing, but I jumped right in using a potholder on my left hand to hold the metal bowl. It cooled while I mixed and I let the kids help hold the mixer after a couple of minutes. The substance quickly starts to change from molten sugar into a joyful, puffy whiteness. Most of the directions I read said to add the salt and vanilla towards the end of mixing, but I was afraid I’d forget and added them right off the bat. Our marshmallows were wonderful so I don’t think it will make much difference.
***Seasoning Note: this is a great time to add other flavors or coloring. For example: orange extract and food coloring to match for orange cream marshmallows, or a lavender extract would be amazing! And there you are, you've got gourmet marshmallows you can claim as your own.***
STEP 6:
Once your mixture has thickened, set the mixer aside and pull out the oil again. Oil a spatula (and here I went ahead and oiled my hands as well) and use the spatula to scrape the stuff into the already oiled and sugared 9×9 inch pan. You can leave the top of the mixture gloppy if you want, that kind of home-made texture is fun, but you could also use the oiled spatula to smooth the top of the marshmallow mix in the pan. Next oil a piece of saran wrap and cover the marshmallows and set aside for two hours. I needed to get on with dinner, so I actually put mine in the fridge overnight (otherwise we get ants) and that worked just fine for us.
STEP 7:
Clean up was a blast. I gave each kid something to lick then sent them sticky and sugar crazed to play in the tub to get clean. All marshmallow residue wipes off utensils easily with warm, soapy water.
STEP 8:
When your marshmallows have set, take an oiled knife, I used an eight inch chefs knife, to separate the marshmallow from the sides of the pan. (You have to oil everything or it will stick like crazy. If you have non-stick spray that may be safer to use on the knife than applying oil by hand.) Next oil your cutting surface. I used a plastic cutting board. Although you oiled and sugared the pan the mallow mixture may still cling. Have no fear. Oil your hand lightly and pull the fluff out and lie it on the cutting surface. Now, sprinkle the top of your marshmallow with powdered sugar. This will reduce stickage the way you use flour when kneading bread. Then either wash the hand you’ll be holding the knife in or use a washcloth for gripping the handle, and start to slice through the marshmallow. Here I got smart. If you press firmly down on the knife you can pull the marshmallow up and away from it. It will come away in a clean tear.
***Holiday Note*** If its a certain season, say Valentine's day, use oiled heart shaped cookie cutters to cut out your marshmallows!***
STEP 9:
Immediately powder sugar all sides of the mallow strip. Continue slicing and dicing until you have a bunch of square marshmallows. I suggest cutting a few smaller marshmallows for the little ones to try.
STEP 10:
These things pack quite a punch and are not for the faint of heart! Toss the cubed marshmallows into a bowl with powdered sugar and toss to coat. And voila. There ya have it folks, homemade marshmallows.
64 Comments
inhaos 13 years ago
i may try and post the steps too.
haha~~~~
woowho 13 years ago
nerys 13 years ago
whats its purpose in this? do I just skip it or replace it with something else?
makalove 13 years ago
porcupinemamma 13 years ago
star folder 13 years ago
woowho 13 years ago
Pure Cane Syrup
Lyle's Golden Syrup
Honey
Molasses
and i quote:
Along with honey, golden syrup and molasses, many times, ordinary sugar and brown sugar are also used as corn syrup substitutes. You can make a simple syrup, by adding 2 cups of sugar to one cup of water, and then boiling this solution over medium heat. While boiling, you have to stir it continuously, till the sugar dissolves completely, and the solution becomes a bit thicker. Now, let this syrup cool, before using it to substitute corn syrup in your recipe. But, generally, honey and golden syrup are the preferred options for substituting both light and dark corn syrup. However, this decision would depend to a great extent on your particular recipe as well.
http://www.buzzle.com/articles/corn-syrup-substitute.html
molasses would make an interesting marshmallow. i also think syrup in general would work: maple syrup marshmallows sound so yummy! if you try any of these substitutions let me know how it works out. :-)
nerys 13 years ago
I also am 100% addicted to honey. will have to try that. Been grabbing a couple extra honey every time I goto wawa for tea I have thosuands of packs of it after 10 years :-) hehe
probablepossible 13 years ago
woowho 13 years ago
woowho 13 years ago
woowho 13 years ago
SageMinto 13 years ago
I've come across so many recipes that require marshmallows, when I haven't got any. But for some odd reason I have the ingredients required to make marshmallows! Talk about fate! 8D
Thank you so much for posting this.
rathmiron 13 years ago
another thing. the gelatin i bought, has an entirely different way of preparing. (it needs to bee cooked) but it's still 250 ml (1 cup). should i just do that?
woowho 13 years ago
woowho 13 years ago
silver912targa 13 years ago
Just made a tray full and they are suuuuper.
Great for the kid's birthday party.
Thanks again!!
kikiorg 13 years ago
I've also substituted the sugar and water for maple syrup. It makes really great tasting marshmallows.
Lastly, the marshmallow is named for a plant (so it's not "mellow" but one of the mallow family of plants): http://en.wikipedia.org/wiki/Althaea_officinalis
Kiki
