Matchstick Rocket
Intro: Matchstick Rocket
This is an instructable of making a matchstick rocket.
The reason that I did this instructables is a reminiscence of the days of my grandpa and I spent time together. That was when he shown me this trick.
STEP 1: Items
Items listed below can be easily bought in your local store.
- Matches
- Candle
- Aluminium foil
- Play Doh
- A nerve to play with fire
STEP 2: The Assembly
- Firstly, I fold two of the matches with the aluminium foil.
- I make sure that both head of the match meet inside the foil.
- Then, I assign one of the matches to act as a rocket is loose inside the folded foil.
STEP 3: Three, Two, Oneā¦ Ignition and Lift Off!
- For the launching pad, I position the candle in front of the Play Doh.
- Now, it time to light the candle.
- Please watch the test video.
HAPPY MAKING!
Please don't forget to vote for me.
16 Comments
offseidjr 7 years ago
good instuctable! I have tried to make a matchstick rocket before and it didnt work. I'll be sure to follow your instructions! :)
IxoraStrawberry 7 years ago
Thanks for commenting.
ProtectTheAlphaWolf 8 years ago
JohnC150 7 years ago
Actually, if he thought of it, than it is all his. Any time two or more people independently arrived at similar solutions to any issue, neither person or group should ever be discredited for their ingenuity.
I'm very honored if someone make use of my ideas (or renewed old ideas) as long as it served a purpose of solution to their problems even though it is sometime too plain simple idea :D
imcp1024 8 years ago
IxoraStrawberry 8 years ago
He roll up two matches head by head inside the paper. Next, he let me hold the other end of the matches. "Careful lad," he advice asking to point it away. Then, he lighted the center. Vuzzzz, it goes!
My instructable is a reminiscence of that days and it just got safer.
Anyhow, I will look for Backyard Balistics' idea.
DreamDabbler 7 years ago
I've seen something similar, using only one match. You have a pin beside the match with the point alongside the head of the match, and the head of the pin outside of the aluminum foil so you can pull it out and leave an open channel. You have to set the match on a bent paperclip or something else it can set on lightly at an angle and be free to move. Then you just hold a lighted match under the aluminum-wrapped match head. I didn't have a lot of luck with it myself, but I did get one to make a little jump.
Then, I remember... Two heads are better that one. How about if I had two heads match together in the foil facing each other. Will it give enough thrust to launch the match?
Yes, it does!!!
Thanks for commenting :-)
tress2323 8 years ago
No way
Sajjad_A 8 years ago
I think was the King of Random's idea....
wold630 8 years ago
Fun! How far does the match go?
But, if you did it in front of kids. They will be thrill :D
