Introduction: Mechanical Pencil Staple Gun
A slightly modified pencil that shoots staples like ten feet. Note do not try to build this at school!
Step 1: What You Need
Lighter
Pencil
Razor Blade
Paper Clip
Stiring Straw
Tape
Pliers
Pencil
Razor Blade
Paper Clip
Stiring Straw
Tape
Pliers
Step 2: Stripping
Using pliers pull off the clip and take off the tip.
Step 3: Trigger Tube
Cut the stirring straw to the same length as the paper clip.
Step 4: Attaching Trigger
Heat up the paper clip and melt a hole through the eraser and take it out.
Put it through the straw and insert the paper clip through the hole and out
the other side about a centimeter and bend it over then bend the bottom part
down and tape the straw to the pencil.
Step 5: Taping Tip
Tape the lead advancing cylinder to the body of the pencil so when you push on the eraser two prongs come out.
