Meta Bracelet
Intro: Meta Bracelet
Meta - short for metamorphosis - was designed in Rhino 3D with the aid its plug-in's T-Splines and Grasshopper. The definition essentially allocates material based on the density of cells to make it stronger in areas of greater permeability on a two dimensional plane. Once the desired pattern is a selected it is then projected onto an ellipsoidal surface. The pattern is then used to split the surface and separate positive from negative which is then offset as a solid. The surface geometry is then extracted of its wireframe and used to generate the smooth continuous surface via T-Splines. The model was then converted from a Rhino file to an STL format and printed on an Objet 3D Printer.
4 Comments
haruthrauff 12 years ago
fungus amungus 12 years ago
kwholgamuth 12 years ago
ancienthart 12 years ago
Either go into more detail explaining all the steps of how you MADE it, or stop spamming us.
