Metal Petals!
Intro: Metal Petals!
This is a fancy instructable for any sort of lady-getting type thing or holiday relating to women of any sort: Metal Flowers!
(the first picture is a Calla Lily, and the second is a rose)
STEP 1: Materials
-Copper or brass sheet. Thin, but not so thin that it's like sandwich foil. how much you need depends on how large you want your flower to be
-Steel or other metal rod of a decent thickness. Again, i've left this extremely variable for the size of your flower. The stuff I'm using is gonna be using is about 1/4" round barstock.
also for the first flower in this instructable (the small rose) for ease of use we're going to use a standard duplex nail.
-Miscellaneous bits n' pieces.
STEP 2: Tools
-Ballpien hammer. Prefer a ballpien but it's not entirely necessary.
-Vice
-Torch and brick or forge. I have a forge, but a propane torch with a wide head or an oxy acetylene turned on low with a rosebud will do. (this is somewhat optional. If you need to anneal your copper/brass first you will need this. Some stuff you buy comes pre annealed and finished. If your metal is overly stiff you'll want this)
-Sandpaper
-Glue (good idea to have around but not completely necessary)
-Vice
-Sandpaper
STEP 3: Now We Begin.
Clip your pieces out of the copper sheet and drill your holes in the middle. Then stack the pieces up and estimate the thickness.
(you can get an idea of what your pieces should look like by looking at a picture of the flower and piecing apart its geometry but i won't get into that)
Take that measurement and add a little to it (for mine i added about a quarter inch) Then weld your nut/washer to the piece of barstock that far from the end.
STEP 4: Optional Step; Annealing
Get your forge and/or torch and brick, some pliers, your metal, and a bucket of water.
Heat up your copper/brass and watch it. When it starts changing colors (don't worry, you'll see it) dunk it in the water with the pliers. If you're using a torch you'll want to get the whole thing hot by drawing the torch around the piece of metal.
It will now be really soft and ready to work.
If your metal is pre annealed you can skip this step.
STEP 5: Stack An' Smash!
Stack your pieces up however you want to arrange them (for some flowers it will matter and others it will not. For the daffodil pictured it does), clamp them in the vice, and then peen it down tight. (and i mean TIGHT. if it jiggles loose you can use glue but i prefer to not have to do so)
STEP 6: Shape the Petals.
Shape your flower petals by bending them up and wrapping them inward with a pair of small needlenose pliers or scrolling pliers. It may help to have a picture handy of the actual flower around to tweak your shape.
STEP 7: Finished!
Now step back and admire your fancy new flower!
If you want to go one step further you can add the actual scent of the flower by putting some drops of the flower's essential extract onto it.
Now the only thing left to do is to give it to your particular lady in mind and enjoy the praise!
:P
Thanks for reading!
:P
Thanks for reading!
11 Comments
ladiesman247 15 years ago
abbabibble2 15 years ago
metalliferous 15 years ago
hay_jumper 15 years ago
Goodhart 15 years ago
LinuxH4x0r 15 years ago
SWV1787 15 years ago
pyro13 15 years ago
