Metric Clock: Take 2
Intro: Metric Clock: Take 2
Some of you may remember my first instructable, the binary metric clock. It was published like a month ago, but I'm too lazy to actually check. After getting an LCD, I've decided to remake a better, easier to read, easier to set, useful version. For those who are not familiar with my first metric clock, I will include a small orientation:
It works like anything does in metric, with days as the base unit.
It can show decidays, centidays, millidays, and microdays.
For reference, 864 seconds are in a milliday.
Again for reference, six in the morning is 2:5:0:000, noon in 5:0:0:000, and 6 in the evening is 7:5:0:000.
I personally believe that a metric clock would simplify time-keeping, and should be use instead of the current system. A metric clock would make sense, as opposed to what is in place now.
Changes since the first version:
Not in binary
On an LCD
Can show microdays
Can be set without a computer
Not in binary
On an LCD
Can show microdays
STEP 1: Supplies
Here is the list of what you'll need:
1 LCD (must be compatible with Hitachi HD44780 driver)
1 10k potentiometer
2 buttons
2 10k resistors
1 Arduino (or clone)
Lots of wire
A breadboard
1 10k potentiometer
2 buttons
2 10k resistors
Lots of wire
A breadboard
STEP 2: Building It
The set up is pretty easy. If you take a look at the picture (created using Fritzing), the blue lines are wires, the big green thing is an LCD, and the resistors are 10,000 ohm resistors. It is remotely self-explanatory.
STEP 3: Code & Explanation
Here is the code, commented for your convenience:
Metric clock
By Alec Robinson, otherwise known as alecnotalex.
Licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License.
#include <LiquidCrystal.h> //Used for writing for the LCD
int deci = 0, centi = 0, milli = 0, micro = 0; //Keep track of each of the units
int setmode = 0; //0 if user is not setting anything, 1 if user is setting decidays, 2 for centidays and so on.
int setbutton = 3, addone = 2; //Pins for buttons; setbutton changes setmode, addone changes the units the user is setting
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //Creates new lcd at pins 7-12
void setup ()
lcd.begin(16, 2); //Begins the 16x2 LCD
void loop ()
lcd.setCursor(0, 0);
lcd.print(deci); //Prints decidays
lcd.print(":");
lcd.print(centi); //Prints centidays
lcd.print(":");
lcd.print(milli); //Prints millidays
lcd.print(":");
lcd.print(micro); //Prints microdays
lcd.setCursor(0, 1);
if (digitalRead(setbutton) == HIGH) //If setbutton is pressed
setmode++; //Changes the mode
if (setmode == 4) //Resets it if the user has scrolled through all settings
setmode = 0;
lcd.print(" "); //Clears bottom row of screen
if (setmode > 0) //If the user is setting something
lcd.print("Setting: ");
delay(100); //To make sure the user doesn't accidently press a button more than once when they dont mean to
else
delay(86.4); //One microday
micro++;
if (micro == 1000) //One milliday
milli++;
micro = 0;
lcd.setCursor(7, 0);
lcd.print(" ");
if (milli == 10) //One centiday
centi++;
milli = 0;
if (centi == 10) //One deciday
deci++;
centi = 0;
if (deci == 10) //One day
deci = 0;
if (setmode == 1) //When the user is setting the decidays
lcd.print("deci");
if (digitalRead(addone) == HIGH)
deci++;
if (deci == 10) deci = 0;
if (setmode == 2) //The user is setting centidays
lcd.print("centi");
centi++;
if (centi == 10) centi = 0;
if (setmode == 3) //The user is setting millidays
lcd.print("milli");
milli++;
if (milli == 10) milli = 0;
Metric clock
void setup ()
void loop ()
lcd.print(":");
lcd.print(":");
lcd.print(":");
setmode = 0;
else
micro++;
milli++;
micro = 0;
lcd.print(" ");
centi++;
milli = 0;
deci++;
centi = 0;
deci = 0;
lcd.print("deci");
deci++;
lcd.print("centi");
centi++;
lcd.print("milli");
milli++;
STEP 4: Determine Metric Time, From Reguar Time
I have changed my method since last time.
Let m = minutes in regular time
Let h = hours in regular time
Let mt = metric time
(h + m/60)/24 = mt
This will return a decimal. This decimal is the metric time.
(h + m/60)/24 = mt
STEP 5: Your Finished Product
You're finished building your fancy new time keeping device! Your glorious new piece of time-telling equipment will greatly help you figure out how much of the day has gone by, and how much is left. Although currently no societies use a metric clock, one can still find many ways to use this device.
In the future, I have even more plans. Once I have the supplies, I plan on making it sync with the satellites, so it can be super precise. Of course, this will not be until a long time. Until then, I hope you enjoy your new clock!
8 Comments
billh51 1 year ago
merelart 2 years ago
etcmn 10 years ago
I write science fiction and developed a metric clock as the time standard in my stories.
Not likely to see one adopted in real life because you would have to have some way to compensate for the fact that one rotation of the Earth does not work out to a nice even number of seconds.
kpkp3030 12 years ago
alecnotalex 12 years ago
Hope this helped!
decidays mean what?
centidays mean what?
millidays mean what?
microdays mean what?
because i am just a primary school student: :)
