Introduction: Michiels Knex Shell Ejection Gun
Also Check Out My Other Instructables:
- My Knex Wii Zapper: https://www.instructables.com/id/Michiels-Knex-Wii-Zapper/
- My Knex Battle Bot: https://www.instructables.com/id/Michiels-Knex-Battle-Bot/
- My Knex Wii Wheel With Auto-Centering: https://www.instructables.com/id/Michiels-Knex-Wii-Wheel-With-Auto-Centering-V1/
- My Knex Rubber Band With Ammo Gun: https://www.instructables.com/id/Michiels-Knex-Rubber-Band-WITH-Ammo-Gun/
This Is My Knex Shell Ejection Gun.
It Uses The "TheDunkis" Mechanism For The Shell Ejection. Its A Pretty Simple Gun, However It Has A Basic Trigger. I Posted These Instructions 'Cause I Couldn't Find Any Clear Instructions And Because Of That I Took Me Some Time To Get The Mechanism Figured Out. It's Very Accurate ('Cause It Uses Those Shells).
Unfortunately You Have To Cut Two Pieces, I Don't Like That. But You Really Have To. Those Black Ball Sockets Look Similar To The Grey Connectors You Have To Cut, But They Won't Work.
Parts List:
RODS:
Green Rods: 25
White Rods: 9
Blue Rods: 7
Yellow Rods: 3
Red Rods: 1
Gray Rods: 4
CONNECTORS:
- Gray Connectors: 26
- Orange Connectors: 16
- Yellow Connectors: 11
- Snow Flakes / White Connectors (8 Teeth): 9
- Small Blue Connectors (Smaller Than Single Teeth Gray): 4
- Black Connector: 5
OTHERS:
- Blue Spacers: 4
- Gray Spacers (To Make 4 Shells): 12
- Rubber Bands: 3
- Cutten Gray Connectors (Single Tooth, Picture 4): 2
If You Have Any Question Or Problem Or Something... Just Leave A Comment, I'll Help You.
Step 1: Front Part
This Is How To Make The Front Of The Gun.
Picture 1: Make This.
Picture 2: Make This.
Picture 3: Connect.
Step 2: Back Part
This Is How To Make The Back Of The Gun.
Picture 2: At The Bottom Add These Three Yellow Rods.
Step 3: Top Gray Rod
This Is How To Make The Top Gray Rod.
Picture 2: Connect.
Step 4: Magazine
This Is How To Make The Magazine.
Picture 1: Make This (Easy).
Picture 3: Put Picture 2 (The Ammo Pusher) Into Picture 3 (The Magazine).
Picture 4: Attach The Whole Magazine To The Gun.
Step 5: Other Things You Have to Do
This Are All Other Things You Need / Have To Do.
Picture 2: Make 4 Of These.
Picture 3: Add A Rubber Band.
Picture 4: Add A Rubber Band.
Picture 5: Add A Rubber Band To The Ram.
Step 6: Loading the Gun
This Is How To Load The Gun.
Picture 1: Prepare Your Bullets.
Picture 2: Pull The Ram Back.
Picture 3: Put The Bullets In The Magazine.
Picture 4: Hold Down The Ammo Pusher And Fire The Gun (So It Won't Fire Any Bullets).
Picture 5: Release The Ammo Pusher And Now You're Ready To Load And Fire The Gun, Have Fun!
14 Comments
11 years ago on Introduction
neat gun
11 years ago on Step 6
myles126 is right this gun BLOWS
12 years ago on Introduction
cool!
12 years ago on Step 6
this gun dodnt work ram dodnt go through conecters
I have since made this and it works well. maybe more guns from you in the future?
Reply 12 years ago on Introduction
I've already made another shell ejection gun (same mechanism) but a bigger one. But i'm not gonna post any instructions 'cause its a large gun. I'll post a slideshow and video soon (up to 2 weeks).
Greets!
Actually I was just talking about ordinary knex guns.
BTW: what did you use to cut the gray connector?
'Cause you can't use "Black Ball Sockets" (there's a little difference between them): http://knex.com/product_image.php?imageid=70 These are little curved to hold the "Black Ball Joint" (http://knex.com/product_image.php?imageid=69) , the cut gray connectors aren't curved. Unfortunately there's no other way to get this working.
These cut gray connectors avoid the blue rods, when they are still in the shell, to eject. When you fire, the rod is off and the shell will eject 'cause the mag pusher pushes them up.
I hope this helped!
I just built the first step right now!
What are the brown tubes on the bullets?
Reply 12 years ago on Step 6
Those are the shells: 3 gray spacers connected with tape.
Have a look at step 6
thnx
nice
