Micro-Sized Miniature Lathe
Intro: Micro-Sized Miniature Lathe
This is a tiny lathe I made last weekend. The motor is from a small hand vacuum motor and is directly attached to the chuck. It won't work with wood, but foam composite from a sign making shop works great.
The power supply is from an old mini radio TV. I believe it's 12 volts and .85 amps. The case is made from scrap Plexiglas, which I get for free from the same shop I get the sign composite from. The fancy on-off switch was attached to the motor when I got it.
Everything is stuck together with JB weld and Loctite super glue ( I swear by this stuff).
This whole project cost me nothing but time, a bit of solder, JB weld, and Loctite. All-in-all about $1.00 worth of bought materials.
It turns very fast. Great for making small wine glass shapes, chess pieces, and barrel shapes from foam composite.
I hope you enjoy the video and slides!
Centering
Finishing up
EDIT This project was so easy, I've decided to make an 'ible for this... I will be using a tape player motor because those are easy to get and will work better than anything of the same size.
Centering
Finishing up
45 Comments
playmoboy 13 years ago
nepheron 13 years ago
http://www.youtube.com/watch?v=JK9iwXN-5AI
clusterflop 9 years ago
No actually, the tutorial on Youtube is for another type wood lathe with a much larger sewing machine motor, not this micro lathe.
Dumchicken 13 years ago
Steliart - Stelios LA Stavrinides 14 years ago
imthatguy1125 14 years ago
omnibot 14 years ago
nepheron 14 years ago
Sounds like the foam is not anchored on the shaft properly. If it wobbles, then the foam is able to move. Your foam may be too long or not secured to the motor shaft enough.
lieuwe 14 years ago
Cutting tools will only lead to a "pocked" surface.
Blunt headed tools result in a smooth surface!
lieuwe 14 years ago
