Minecraft Rollercoaster
Intro: Minecraft Rollercoaster
In this instructable, i will be showing you how to make your very own minecraft rollercoaster in six easy steps.
STEP 1: Lay Out Your Track
Design the layout for your track. It doesn't matter how you do it, as long as the track is continuous and returns to the starting point, so have fun and be creative with it.
STEP 2: Adding the Rails
Once you design your track, add the railing so you can move across the track. After all, you can't have a rollercoaster without rails.
STEP 3: Powered Rails
The red powered rails are required to accelerate and move the minecart across the track. Make sure you space them out evenly throughout your track so they can keep the cart moving continuously.
STEP 4: Adding Redstone Torches
The powered rails must be powered by something else to work, whether it be a lever, button, or redstone torch. In this case, the redstone torch is definitely the easiest way to go. They can be placed directly next to, above, or below the block that the powered rail is placed on to give it power. In my case in decided to place my torches directly under my powered rails. Keep in mind that any powered rails connected to the rail being powered also receive the power.
STEP 5: Back to the Start
At the starting point of your track, add powered rails and a lever so you can start the ride for yourself. The lever will activate the powered rails whenever flipped, so you can place your minecart and get in without it going anywhere beforehand.
STEP 6: Enjoy the Ride
Lastly, place a minecart at beginning of your track, get in, and press the lever to start the ride. Enjoy!
4 Comments
74854 1 year ago
ib10161 4 years ago
Penolopy Bulnick 5 years ago
DIY Hacks and How Tos 5 years ago
