Minecraft: the Night Machine
Intro: Minecraft: the Night Machine
This Minecraft invention will present you with a new challenge! It will furnish you with a more action-packed Minecraft life! After you have gone through this Instructable, you will be able to build the Night Machine, a mechanism that gives new meaning to the gamemode name "Survival." Enjoy and please leave a comment :)
Note: I invented the Night Machine independently of anyone else on March 25, 2014.
STEP 1: Preworld Lobby
- Pick Creative Mode.
- Put cheats on.
- Put the Bonus Chest on. (It will be helpful when you switch to Survival Mode).
STEP 2: Clear the Area
Okay, you've spawned in the world. Make a flat area like this. Make sure it is open to the sky. This is where your Night Machine will go. Dig down one more block and replace the dirt in your area with Bedrock. I did not do this, but if you do, finishing will be much simpler. This Bedrock area is where the Night Machine will go.
STEP 3: Materials
- 4 Redstone Repeaters
- 5 bits of Redstone wire
- 1 Redstone Torch
- Bedrock
- 1 Command Block. You can't find this in the Creative Mode inventory, nor can you get a Command Block in Survival. To obtain it you must type into the chat:
/give (your Minecraft name here) 137
STEP 4: The Timing Mechanism
You will need to construct a Redstone Repeater clock, like in the picture. Put the delays on the shortest delay as shown. If you are having trouble following the picture, go here:
http://www.youtube.com/watch?v=i_QEovZAv0k
Put another bit of Redstone wire on the corner.
STEP 5: The Command Block
/time set 18000
This is the command for midnight.
STEP 6: Start Her Up
Place a Redstone Torch next to one of the bits of Redstone wire. Destroy it immediately. The Repeater circuit should be cycling, and the time of day will change to midnight. However, your screen will soon be cluttered with messages. We will fix that later.
STEP 7: The Casing
STEP 8: Final Settings
Alright, you are done building things, so get rid of all the stuff in your inventory. No cheating!
Now give the Survival command:
/gamemode 0
This will change the game mode to Survival.
And that's all well and good, but at this point, you are probably pretty annoyed with the text filling your screen. To fix that, pause the game and pick Options... > Multiplayer Settings > Chat. Click the button until it says "Chat: Hidden." This will remove the scrolling text, but you will be unable to give any other commands while this feature is on. After you have made the chat disappear, change the difficulty to a non-peaceful setting to begin the fight.
That's it! Now start fending off the gobs of mobs that will come for your blood. Good luck! You are going to need it.
7 Comments
ruarose16 8 years ago
Slugkid 9 years ago
I really just created an account for this comment.
Two commands, no command block:
/time set night (Or whatever number you want, 18000 works)
/gamerule doDaylightCycle false
The moon will stay in place. You can also do it at dusk for some sort of medium difficulty or at full blown day to only have mobs spawn underground. Also I recommend not turning cheats on during world creation, but after creating a no-cheat world, open it to LAN, allow cheats, cheat there, close it, and enter again, so you can't just /gamemode 1 whenever you are about to die without opening to LAN first.
Cheers!
pcanywii 10 years ago
Plo Koon 10 years ago
Yes, but that would only set it to midnight one time. Day would soon arrive. However, the Night Machine is designed to give the command repeatedly, so with every passing moment the time blinks back to midnight.
craftclarity 10 years ago
I'll have to try this one out....
Hope you like it!
