Introduction: Minecraft Wooden Warrior
In keeping with the Minecraft aesthetic, we created an action figurine for our nephew with non-rounded joints to keep the blocky presentation it is known for in the game.
Maker Suggestion: This design has the potential to be scaled smaller or larger depending on material and tool availability. However, the drill press was invaluable, whereas most of the other tools could be substituted. You, the maker, can carry on the ingenuity within this project in that the mechanisms created can be recreated in a myriad of other ways depending on the materials available. So, don’t limit yourself to our specific list of components.
Step 1: Materials and Tools
Materials
2 – 2” x 2” x 36” Square Dowel Rods
1 - ¼” Round Dowel Rod
12 – ¼” x 1 ¼” Dowel Rod
1 – ¾” Dowel Rod
1 – ¼” Craft Plywood
1 – ½” PVC Pipe
2 – ½” NPT to ½” Hose Barb
4 – ½” Hose Barb Plug
4 – 15/32” x 1 1/8” Spring
1 – 2” Wood Ball
1 – ¼” x 2” Hanger Bolt
1 – ¼’ Pronged Tee Nut
12 - #6 x ¾” Flat Head Screws
Plastic Epoxy
Tools
Bench Top Drill
Drill Vise
Miter Saw
Combination Sander
Hand Drill
Rotary Tool with Wood Carving Bits
Scroll Saw
Paddle Bit Set
Adjustable Paddle Bit
Hole Saw Set
Drill Bit Set
Router Bit Set
Countersink Tool
Hand Clamp Set
Caliper (for measuring)
Hammer
Philip Screwdriver
Flat Head Screwdriver
Punch
Adjustable Wrench
Vise Grip
Step 2: General AutoCAD Layout
See "Minecraft Wooden Warrior" pdf.
Step 3: Making of the Shoulder and Leg Joints
1. Cut and assemble components as shown using Epoxy
2. Drill and cut out slot for 1/4" dowel rod to slide back and forth
3. Drill through the assembly with a ½” drill bit to the inside surface of the plug to allow clearance for the spring to drop in
Step 4: Making of the Body Sections
1. Set up block on drill vise (for two blocks)
- Drill with the hole saw to make a recess cut for the shoulder cap
- Drill with paddle bit for the shoulder joint socket
- Drill with smaller paddle bit for the stabilizing dowel rod, making sure the tip of the bit goes through the other side of the block
- Drill holes for dowel pins to join two sections together
2. Make shoulder caps (for each arm)
-Create template for shoulder cap by drilling an 1/8” deep circle with the same size hole saw as used on the block for body in the ¼” craft plywood
-Drill with paddle bit for the PVC pipe to slide through
- Cut out shoulder cap and sand to fit in pocket
- Drill and countersink pilot holes for flat head screws between the shoulder cap and the body section
Step 5: Making of the Arms
(for two blocks)
1. Drill with paddle bit to create pocket for shoulder joint plug to fit, finish depth with router bit to create a flat bottom
2. Tilt drill press table to chamfer the hole creating an elongated slot to allow shoulder joint to pivot
3. Chamfer the shoulder point pug
4. Drill for the dowel rod to create pivoting motion
Step 6: Making of the Legs
(for two blocks)
1. Drill with paddle bit to create pocket for leg joint plug to fit
2. Tilt drill press table to chamfer the hole creating an elongated slot to allow leg joint to pivot
Step 7: Making of the Head
1. Cut four equal length pieces of the 2” square dowel rod, drill holes for ¼” dowel pins to join, glue four pieces together
2. Drill with hole saw to create recess for neck cap
3. Use adjustable paddle bit to create pocket for the 2” wood ball
4. Make neck cap similar to shoulder caps and fit to the block for the head
5. Drill out 2” wood ball for the hanger bolt
6. Cut a short piece of PVC pipe for the neck
7. After joining the body sections drill in the center of body assembly to install the T Nut and give clearance for the hanger bolt to screw through it
Step 8: Assembling the Shoulder and Leg Joints
1. Insert spring into shoulder and leg joint assemblies and compress spring to insert a shortened dowel pin that is no longer than PVC pipe width
2. For shoulder joint, insert assembly into body section and screw shoulder cap onto the body section
3. For leg joint, insert single hole side of assembly into body section securing with a dowel pin
Step 9: Assembling the Arms and Legs
1. Fit arm over the shoulder joint and align hole for full dowel pin with shortened dowel pin holding the spring; drive the full dowel pin through, pushing the shorter pin out
2. Do same operation for fitting leg over leg joint
Step 10: Assembling the Head
1. Screw hanger bolt into the 2” wood ball
2. Drive in T nut in the body section; set neck cap and PVC neck piece over the T nut
3. Screw the wood ball into the T nut
4. Set head block over the head ball; screw neck cap into head block
Step 11: Future Mods
- Give to nephew to paint
- Make accessories like pick axe, bow, sword, shield, ect.
