Minecraft Time Machine!!!
Intro: Minecraft Time Machine!!!
Have you ever wanted to be a time traveler in Minecraft, but known it was impossible? Well, now you can!
STEP 1: Get a Command Block
Type /give @p command_block and press enter. A command block will appear in your inventory!
STEP 2: Make It Do Something
Right-click the Command Block and type time add 20000 and click done. You could also type time subtract 20000, but remember, you can't have both at once. It will only work if you have one or the other.
STEP 3: Make It Look Cool
Place 4 blocks of your choice (I used obsidian) around the command block, as shown. Place 1 stair block on one of the blocks (not the command block) and place a blank sign on both sides to make a chair. Place a 2-block high tower on the side opposite of the chair. Place an item frame with a clock in it on the top block of your tower. Place a carpet of your choice on the command block, and make sure to sneak when you do this or it won't work. Finally, place a power source (button, lever, etc.) on one of the 2 remaining blocks and you're done!
STEP 4: Have Fun!
Use your time machine to travel through time!!! As you can see, it really works! Have fun!!! I'm in the First Time Author contest, so vote for me!PEACE OUT!!!
21 Comments
Hailerdafon 3 years ago
RMP2003 3 years ago
roo5430 3 years ago
RMP2003 3 years ago
RMP2003 3 years ago
He shows the machine and how it works. I’m so sorry for not doing this earlier.
SlimyJoe27 3 years ago
RMP2003 3 years ago
It does work, but not quite in the way you’d expect. What it really does is change the time of day using the “time set” command. The number you put in is actually a time.
So it can’t visit the past or future, but you can skip to any point in the day you want!
Acf201 3 years ago
RMP2003 3 years ago
Acf201 3 years ago
Minecrafter4435 8 years ago
What command do you put in the command block? and do you need mods?
the_gh0st_ 4 years ago
helloperson4 5 years ago
Jeph Diel 8 years ago
now if only Minecraft would modify tohe world to the way it was previously when you went back in time.
RMP2003 8 years ago
I fully agree. And thanks!
TrevorG52 6 years ago
on demo
That_Jamie_S_Guy 8 years ago
RMP2003 8 years ago
I've actually used this to build the TARDIS a few times. I'm considering doing that next!
amberrayh 8 years ago
This is cool. Does it really work? The only thing that says the time are your screen shots. Good luck in the contest!
