The Mini Desktop Lathe
Intro: The Mini Desktop Lathe
here's how to make a mini desktop lathe!
STEP 1: Mini Desktop Lathe
Parts
Motor . One to drive and one to act as a stop
A plank
Staples
30 v supply or other power source
Bolts
2 steel bars to guid the small motor
And a clamp or 2
STEP 2: Drive Motor
The motor that drives the lathe needs to be bolted squared to the end of the plank I only used 2 bolts so I could loosen one to line Up the motor
STEP 3: Guid Rails
just use big staples like the ones you use to secure wires to a wall to hold the bars in place
STEP 4: Put the Last Motor On
Put the small motor on the rails and clamp it with the work piece between the two motors
STEP 5: Other Steps Optional
you could Grind a fork in to the shaft of the motor to grip the part. ( i did )
you could Add a directional switch (google a schematic) (i did)
And you could bolt it to a table (mines just clamped)
use a motor with more torque (i didn't)
