Introduction: Mini Solar Car
Solar Power begins its journey 1,000,000 years ago at the heat of the sun where matter is being to energy at a sub-atomic level.
The Sun's energy reaches the surface of the Earth with a power of one kilowatt per square metre(1.1 horsepower per square yard).
Step 1: Parts Needed
1.Coroplast frame-to hold the solar panel,motor&axles.
2.Screw eyes-4nos.
3.Wood block-2nos.
4.a)Shorter axle shaft-holds two wheels.
b)Longer axle shaft-holds driven pully as well as two wheels.
5.Wooden wheels-5.
6.Tubing-to be cut into 4nos ,1cm pieces asin-lineshaft retains.
8.Pully.
9.Motor.
10.mounting clip-to hold motor firmly to body.
11.Elastic band.
12.Solar panel-1.5v,500mAmp.
Step 2: Making of Mini Solar Car
1)On the coroplast body use a push pin to mark four locations for screw eye (axle holder).You will want your axles to be parallel and running straight ahead-consider this as you mark the holes for the axle holder.
2)Insert screw eyes through coroplast and into wood blocks.If necessary,wider a starter hole for the screw eye in the wood with the push pin.When screwing in the screw eyes,you can use a dowel as a level to make turning easier.
3)Ready to receive axles.
4)Select the shorter axle and two wheels.
5)Using sandpaper,very lightly sand the end of the dowel,and insert into wheels.
6)Snippets of tubing are used as "in-line shaft retainers".Cut four small pieces of lengths 1 cm or 1/4 inch.
7)Work the tubing piece onto the axle/shaft.
8)Slide the tubing down the shaft.
9)The"in-line shaft retainer"keeps the wheel from rubbing against the body.
10)With the axle in place through the screw eyes, slide another tubing piece onto the shaft and mount the second wheel.
11)Select the longer axle, two wheels, and the red pulley.
12)The small red pulley may require that the axle be sanded. To keep the dowel round,twist the axle in folded sandpaper.Do not stand off too much-the pulley must grip the axle firmly.
13.Slide the pulley onto the axle.(if the pulley is loose,try jamming a piece of masking tape under it,or use a glue gun.
14)Attach a piece of tubing and a wheel.If the wheel is loose,you may use wood glue or white paper glue to hold it.
15)Mount the driven axle, slide on another piece of tubing,and the last wheel.
16)Place the motor(with motor pulley attached)into the motor clip.
17)Attach the motor clip to the body of the car with a small piece of double tape.
18)With the elastic band drive-belt around the driven pulley and the motor pulley,position the motor clip so that the elastic band has an easy tension-not too loose,and not too tight.
19)Attach the alligator clips of the solar panel to the two metal terminals at the back of the motor.Solar panels produce direct current electricity.Note that reversing the connections at the back of the motor will reverse the direction of the motor's spin.
20)Run in the Sun!try holding the solar panel on tighter with a small piece of scotch tape or velcro. You can as well,using recycled materials,design a movable holder for the solar panel,to let it turn toward the Sun.
Earthjustice United States of Efficiency Contest
19 Comments
10 years ago on Introduction
what is the capacity of the motor??? and what type of solar panel can replace.......am going to do this project please help me!!!!!!!!
very nice!.......really amazing.....
11 years ago on Introduction
what is the size of the coroplast base?
12 years ago on Step 2
ITS So NICE BUDDY>>>>>>>>GREAt WORK...THANKS
12 years ago on Introduction
from where i can buy these items
My brother was going to create a solar project for his science fair with my parents aico furniture. He figured he would need to hook about 750 panels together to get an ottoman to move...
im building this for a science project. what voltage of motor did you use?
13 years ago on Step 2
hey gentleman you are great.actualy i was doing my mini project on this subject .i need to know more about tractive effort & weight ratio.....if u could provide me information on it.I will be pleased for this did.my e-id priyaranjanbvb@gmail.com
Reply 13 years ago on Introduction
U must want to use material which are very less.You want to less the weight as much as possible
i want to know whether we can use switch reluctance motor.and i want to know what type of motor you used in your project??...can u guide me for my final year project!!!
This project i have made is simple & can do by all.So i didn't use much materials in it.U can use anything for perfecting your project and then i have used a normal motor to run this car.
13 years ago on Step 1
what type of motor did u used?
hey man ur awesome gr8 project.... thanks for ur i'ble very useful, by d way i think ur a Indian right??
how do you joint the wires to the solar panels
with aligator clips straight to the motor
14 years ago on Introduction
How much did the solar panel cost?
It will cost nearly $12
14 years ago on Step 2
Hey buddy i m nivedhan I came thro ur instructions for a solar car.It was awesome man great work keep it up..I m expecting more work from you...
going into detail on the parts, even making whole section on one part would be great, but great idea
