Mini Sumo
Intro: Mini Sumo
Today we will explain how to perform the design,
operation, and construction of a sumo robot, a robot is considered an automatic programmed machine to accomplish a certain task. In this opportunity, our robot will have the task of facing another robot on the battlefield whose The aim is to move the opponent out of the field of play, for this we will explain here the step by step and the occasional key to the elaboration.
For the development of this project, it is necessary to have the following materials:
STEP 1: PCB
For the elaboration of our robot we will need a PCB
this is the one in charge of connecting each one of the components for optimal functioning of the circuit; This PCB is designed and ordered to be made specifically for this sumo robot model. This PCB is designed with a double layer which means that we have to weld both sides to connect the two tracks through holes that connect the two sides, these are called True holds.
STEP 2: COMPONENTS
We proceed to place each of our components in the
corresponding areas as shown in the following image
The first thing we must do is solder our Truholds points, we must be very careful when welding each of the components as it is possible to lift the tracks of the PCB.
STEP 3: CHASIS
For the design of our chassis, we can use AutoCAD or
any other design program, here we will look for ways to optimize space since our robot must meet a set weight, the lighter the better the chances of winning.
STEP 4: CODE
In order to give life to our beloved robot, the last
thing we have to do is take a hot glass of coffee to sit and think and program your sumo, but since you are here reading this tutorial, we have good news here you will find the code ready for you to enter in action with your robot and be the best.
STEP 5: CONTROL
To manipulate our little friend we will resort to a
wireless control controlled by Bluetooth from the comfort of your Smartphone, in the following link that I will leave you next you will be able to see the step by step to create your personalized remote control as you want.
