Miniature Anvil
Intro: Miniature Anvil
This time I have made a mini anvil for my future collection of mini-tools. I have tried to be as similar as an anvil of original size using certain details that are usually seen in blacksmiths' anvils.
My inspiration came from the genious Marco Terenzi
If you like the video please Subscribe to my Youtube Channel.
I would also apologize for my English as a non-native English speaker some terms are very difficult for me. Forward, Instructable!! I will be happy to answer any question.
STEP 1: Materials and Tools
Materials
- Beech Wood
- Copper block
- Little chain
- Old Windscreen wiper
- Little Eye Screw (2 Unit)
- Sandpaper
- Wood Glue
- Wood inserts (Threaded)
- Metal Nails
Tools
- Saw Metal
- Metal Files
- Ruler
- Drill Press
- Similar Dremel
- Japanese Saw
- Hammer
- Polishing disk
- Pliers
STEP 2: Anvil's Drawing
I began marking the silhouette on the copper block. I looked for different anvil drawings and finally I decided to use this (document attached).
Firstly, I only marked the sides and then for the curved areas I used a very useful rule for these type of jobs.
STEP 3: Cutting the Silhouette
In this step I just cut the main anvil silhouette. For the curved areas I used a bit drill to speed up the work and give it a better finish. For the rest of the cuts, I used the metal saw and extreme patience...
STEP 4: Cutting Rounded Edge
With the attached drawing, I mark the thickness of the anvil and cut the excess material. Little by little it takes on the shape of an "anvil"!!
To get closer to the final size I use files in order to achieve grater accuracy.
In these steps I still do not intend that the surfaces are perfect, I simply delimit the proportions of the piece.
STEP 5: Anvil's Horn
I use different files to define the anvil horn and as if it were a pencil, I sharpen it to achieve a symmetrical surface and as realistic as possible. It is a laborious work and as you are removing material it becomes more delicate, since removing an excess of material would ruin the appearance of the anvil.
STEP 6: Polishing
In this step I was still not very clear about the aspect I wanted to give the anvil: whether a new look or on the contrary, a degraded appearance...
I decided for the moment to give it a new look: I started sanding the anvil with the following grids: 200, 300, 500 and 1000 and finally I polished it with polishing paste so as to get a shiny look. I really did not want to have that shine, but one of the peculiaryties of the copper is that it oxidizes very fast and it was a matter of days that it took that old touch. And that's how it was...
STEP 7: Anvil's Stand
For the stand I used beech wood: I could use a single piece of wood but as I wanted to give it the greatest possible realism I used small pieces stuck imitating a robust, hard and heavy stand.
STEP 8: Stand Details
In most of the old anvil stands, blacksmiths put around a reinforcement to prevent wood loosening. I came up with the idea of taking advantage of the small metal splints that the windscreen wipers of the cars have, since their dimensions were ideal for this purpose!
With the help of pliers, I shaped it until getting around the piece of wood and then I hammered it with gold small metal nails.
I used a walnut effect tint to give it and old color effect.
STEP 9: Clamping System to the Anvil Stand
To hold the anvil to the stand I used a wood insert and a screw. Possibly, it would have been enough with epoxi glue but as maybe one day it falls up into the hands of a child... better to assure it well :-)
STEP 10: More Details
Not happy with the realism achieved so far, I put a small chain fastened with two little eye screw. A delicate and laborious work due to the size of the parts.
STEP 11: Final Conclusions
I could have done more small details such as small supports to store the hammers, but maybe I would have recharged it too much worsening its appearance. I am quite satisfied with the result, although I would have liked to use stainless steel.
I hope you like it and remember that I will be very happy to solve any doubt.
24 Comments
Dangerously Explosive 5 years ago
BayRatt 5 years ago
Mikhandmaker. 5 years ago
Kenno79 5 years ago
Kudos
Julia J Barton Designs 5 years ago
hoozdman 5 years ago
KryptoTSD 5 years ago
SteveDay72 5 years ago
Nice work though. I'd like to see the rest of your collection.
[Edit]...
If you want more heft than aluminum you could use zinc. Zinc can also have a dark chemical finish applied using black patina for lead&solder, it is sold in craft stores.
https://youtu.be/MXzR5p5AMnM
ElChick 5 years ago
SenKat 5 years ago
Peter MC1 5 years ago
