Miniature Football Field Goal, Football, and Grass (Made Out of Wire)
Intro: Miniature Football Field Goal, Football, and Grass (Made Out of Wire)
I had some free time, so I decided to make a field goal, football, and some artificial grass. All this is done with wire. This is for the "Weekly Challenge: Wire" contest
Items you will need
- Soldering iron
- Solder
- Saftey glasses
- 18 AWG wire or larger.... it needs to be uninsulated wire!
- Ruler or alternate measuring devise
- A couple of heavy duty pliers
- optional ... a handy vise with alligator clips
- Wire cutters
- piece of styrofoam
- scissors
- green marker
- Razor knife
- 18 AWG green wire
Items you will need
- Soldering iron
- Solder
- Saftey glasses
- Wire cutters
- scissors
- green marker
- Razor knife
- 18 AWG green wire
STEP 1: Stretch Wire!
First off the wire needs to be straight. Do the following in order to achieve this!
- Cut off a couple feet of wire
- Grip one end of the wire with pliers, then wrap the wire around the pliers a couple times
- Then do the same thing with the other end of the wire and other set of pliers
- Put one end on the ground and stand on it
- Grab the other end with both hands and pull hard
- You will actually feel the wire stretch a little bit
- At this point you now have made the wire straight
STEP 2: Cut Wire / Assembly
Cut 3 pieces of wire 3 1/2" inch
Solder together as the picture shows
STEP 3: Cut Wire / Assembly
Now cut a piece of wire 5 1/2" to 6" inches
after you cut this wire, you need to put a bend in it; I used the neck of a bottle of water.
I just judged it.... no need to be perfect
Then I soldered it to step 2
see pictures
see pictures
STEP 4: Make Some Grass
I cut a piece of styrofoam any size you want
color it green with a green marker
cut out small 1" inch pieces of 18 AWG green wire
fold them in half and stick them into the styrofoam
follow the pictures
follow the pictures
STEP 5: Make a Little Football
I bent 4 pieces of wire around a quarter
then soldered them together in the shape of a football
see pics
see pics
STEP 6: Finished Product
Now just stick the field goal post into the fake grass and add the little football for a nice touch. All Done
Oh ya..... Go Browns....................I know ..... I know!!!
