Miniature Golf (Putt Putt) Course
Intro: Miniature Golf (Putt Putt) Course
You could just as easily frame up the courses with 2 x 4s and plywood as the deck subfloor. I'll detail the construction in the following steps.
STEP 1: Materials
2x4s Pressure treated (unless you have 3 swimming pools panels laying around)
4x4s Pressure Treated
3 4 foot by 8 foot 1/2 plywood
indoor/outdoor carpet
Metal Kid's slide
Indoor/Outdoor Adhesive
4 inch diameter PVC pipe
2 inch diameter PVC if you want to have a course lower to putt down too
various obstacles
3/4 inch plywood
We had quite a few things laying around the house. The biggest expense was the indoor/outdoor carpet. We spent about $150 U.S. dollars in 2010 to build this.
STEP 2: Build the Bases
STEP 3: Create Bases for the Courses
For each course, we dug 4 post holes to the frost level (one post hole for each corner of the rectangle). We then inserted pressure treated 4x4s into the post holes and filled the remaining area of the holes with concrete. We left about 3.5 inches of 4x4 out of the ground. Make sure the 4x4s are level with each other.
STEP 4: Mount Rectangular Bases Onto the 4x4 Foundation
STEP 5: Put on the Carpet
With a caulking gun, put indoor/outdoor adhesive onto the deck of the courses. Use a trowel that has grooves in it to spread the adhesive onto the deck. Cut the carpet to size before putting the glue down! After gluing, put the carpet on the deck. Use a roller to make sure the carpet is flat and pressed down onto the glued deck. We didn't have a roller, so we made one out of 4 feet of 4 inch diameter PVC and filled it with concrete and let it harden. After 24 hours, you can carefully cut the holes out of the carpet. Once you're finished putting on the carpet, nail pressure treated 2 x 6s around the perimeter of each course so the ball stays in play and you can bank the shots.
4 Comments
ElvenChild 13 years ago
mikeandre 13 years ago
aaronXtreme 11 years ago
JimKelleher 13 years ago
