Introduction: Miss La Sen Candle Holder or Lantern
When you are looking for a meaning craft to make, you should make this Miss La Sen item.
Step 1: Download This Pattern to Trace on the Art Paper or Foam. Print It in A3 Size Paper.
Step 2: Cut the Candle Holder on the Foam or Paper. You Can Glue the Glass Paper on Each Oval Hole of Each Petal in Order That the Light Can Go Through.
Step 3: Use the Hole Puncher to Punch the Holes Like the Sample and Pierce the Arrow of Each Petal Into the Hole of the Next Petal.
Step 4: Cut the Sepal on the Green Paper.
Step 5: Glue the Sepal Under the Petals.
Step 6: If You Just Want to Make the Candle Holder, You Can Put the Candle in This Holder and Stop Here. If You Want to Make the Lantern You Should Continue to Make the Following Steps.
Step 7: Cut the Top Bracket
Step 8: Punch the Holes on the Top of Each Petal.
Step 9: Pierce the Arrows on the Top Bracket Through the Top of Each Petal.
Step 10: You Cut the Top Bracket Like the Pattern and Then Use the String to Hang This Lotus Lantern.
Step 11: Download the Pattern for Miss La Sen Shape and Print It in A4 Size Paper. You Cut the Elements and Then Glue Miss La Sen on One Petal of Lotus.
Step 12: If You Want to Make 2 Layers for This Lantern, You Can Cut the 4 Petal-pattern. It Is Inside of the First Layer. Then You Punch 4 Holes at the Tops of the 4 Inside Petals.
Step 13: Cut the 4-petal Pattern Like the Picture.
Step 14: Punch the Holes and Pierce the Arrows Into the Holes.
Step 15: Put the 4 Petal Pattern Inside the First Layer.
Step 16: Use the String to Tie the Tops of 4 Petals Together. You Have the 2 Layer Lotus Lantern.
Step 17: If You Want to Make 3 Layers for This Lantern, You Can Download This Pattern. It Is for 5 Petal Layer. It Is Between the 6 Petal Layer and the 4 Petal Layer.
Print it in A3 size paper.
